DoubleTap
- Dec 16, 2010
Do people really buy $2500 magic boxes to make their sound system better?
I know about Oxygen Free Cables and all that, but good grief, this is just pure quackery.
http://www.ebay.com/itm/Acoustic-Re...=US_Audio_Cables_Adapters&hash=item2c6bd58ea1
Acoustic Revive RTP-6 Ultimate Power Supply Box.
This is one exotic passive power distributor. There are brass carved out large foot, white are height adjustable.
Combination of 2017 Duralumin box and brass foot will eliminate both materials resonance frequency.
Eliminates noise and static electricity non-contact and non-magnetism
RTP-6 ultimate`s box is filled with Green carborundum, Tourmaline powder and natural quartz powder to eliminate noise and static electricity without no contact and non-magnetism
Most of power supply box uses series type noise filter
But series type filter transfers noise elements to heat by magnet which not only absorbs noise, it also absorbs important electrical energy
Also the magnetic body produces magnetic distortion by the noise absorption which adds a distorted feel and thinness to the sound
This is because an electromagnetic wave absorbent material itself is a strong magnetic body
Also parallel type noise filter or choke coil can not avoid loss in transmission energy
It eliminates noise buy it takes away feeling of restraint and energy feel from the sound
Green carborundum has no side effects because it non-magnetic body
It only absorbs electromagnetic wave noise which is produced from receptacles and internal wiring
Green carborundum is the only electromagnetic wave absorbent material which improves sound quality and S/N ratio
Also the Tourmaline powder releases negative ion and keep the amount static electricity very low
The natural quartz powder releases far infrared rays which has an surface activation effect. This leads to very realistic and sound filled with a feeling of throbbing pulse
Specification
AC Outlet: Provides 6 outlets
Size: W 140 x D 233 x H 70 mm
Weight: 6Kg
Warranty:::
Comes with 1 year full Japan warranty.
Specification
Weight: 6Kg
Warranty:::
