If there's no more cake left, could I use your workshop for my next project?
Looking great, marvelous job
*CLAPS* I seriously am amazed at what you are doing. By the way where did you get that LCD from? I wish I could do this but sadly I do not have the tools for this kind of operation.
Lol, I made some beer bread today that is absolutely delicious. If you come here, you're welcome to a few slices
Sure, just let me get into my private jet and fly to your place
Progress looks good, it's easy to see now how the final case is going to look
A - Mazing.
Awesome, I'd put two strips of brushed sheetmetal over the back where the rails are glued on so that the ugly bubbles and screws aren't visible.
Yea spare-flair has a good point but still looks amazing. How much did you pay for your LCD's?
This is amazing, I'll be watching this thread and looking forward to completion!
Dude, damn. Good work.
Good suggestion. I don't know if it's necessary though; it's on the back of the case and you can't really see it unless you put your nose about 5" away from the acrylic. I'll look into it though.
Well, I can see it clear as day from this picture and it is bugging me.
How are you going to get video from it? Are you planning on doing a DVI extension like you did with the power cables?
As for the bubbles on the back, I'd say it'd be hardly noticable once it is full of liquid.
What do you mean exactly?
As for the bubbles, that's how I'm leaning as well. Covering it up with a piece of aluminum would be difficult since there isn't an easy place on the bottom frame to attach the aluminum to. (nor on the top for that matter).
Are you going to cover up those screw heads? Looks like rivet all around....and thats what made me change my case over to a P182. Clean look. Maybe you cover it up with aluminum or something to get that clean look.
looking great
Well, you could glue on non-transparent strips of plexi to cover it up or so
Awesome work. I personally would not be too troubled by the bubbles on the back. but you could double sticky tape some aluminum strips over the back covering up the drawer slides.
You could sand the back plexi peice to make it have a frosted look - would look quite slick imo.
Looks amazing so far... cant wait to see this compleated. just curious, knowing how much time you put in so far... and you were going to sell this, what price tag would you put on this?
PS - I like the look of the screws myself.
Oh, I would just glue or epoxy the aluminum sheetmetal strips to the plexi. It's just those bubbles and glue residue and exposed screws don't look very nice. Could also get sheets of double sided tape and cut out the right size rectangle for the cleanest look.
Lookin' good.
btw - It's really hard to put a price tag on something like that. It's way more than materials and computer hardware.
I've had bad luck epoxying aluminum to plexiglass in the past. I epoxied the window on the side of my last case to the aluminum and it kind of just fell off after a few months. Then I tried double sided tape, which dried out after a while. I kind of want to leave the back piece of plexi as is. It looks fine and I'd like it to let the light in.
Sheets that are only as wide as your rails won't make a different to the light getting in as the rails block incoming light anyway.
Bah, it's just me. Knowing that something imperfect was visible just drives me insane after all the lengths you go through to fabricate these parts and remake ones you felt were off, etc...seems like a waste.
I also like a clean case and would do something ridiculous like grind all the screw heads flat and jweld some new aluminum on the sides but that's just me.
I like the look of the case. Its like walking into a Chipotle and getting that 'industrial' look to the place.
While the bubbles from the epoxy do detract from the overall finish of the case, I dont think its worth trying to find a solution to cover them up. I think two strips of metal, rail width glued to the other side of the case, would look like a cheap/ quick fix.
Well, I assume you want to hook up a monitor to the video card. Right? Or is the screen on front going to be the only monitor?
I can't image you're going to run a DVI/HDMI cable straight into the case without allowing for it to be disconnected on the backside(top).
Great project log! Always been a fan of these types.
My only suggestion so far would be to put the hot liquid inlet at the top to it takes the hottest material away, otherwise it looks like you might just get a cold loop going on the bottom and the only cold stuff on the processor would just percolate up and not be as efficient as it could be.
Excellent workmanship though!
Read through the entire log just now, some very impressive work!
One thing bugs me about having both the inlet and outlet on the bottom though, convection in liquids is significantly harder to overcome than it is with gasses, I fear warm oil will collect at the top of the tank, and have difficulty finding its way to the radiator.
Would your design allow for an extension tube on the inlet to draw warm oil from upper part of the tank?
Thank you! Yes, I plan on outputting the cooled oil near the CPU and having the inlet draw in from near the GPU's.
Still looking great!! Can't wait for the completion!!!!!!!
