The MCW60™ VGA waterblock
Discussion in 'Water Cooling' started by Bio-Hazard, Feb 2, 2006.
  1. Bio-Hazard
    Bio-Hazard 2[H]4U
    2,312
    Jun 8, 2004
    "The MCW60™ VGA waterblock is a next generation liquid cooling solution for high-end graphics processors. It evolves from the award winning MCW55 by receiving the same base plate technology as the Apogee water-block for enhanced heat dissipation, and a redesigned injection molded housing for universal compatibility with all liquid cooling systems. "
    http://www.swiftnets.com/products/mcw60.asp
    [​IMG]
  2. el rolio
    el rolio 2[H]4U
    2,495
    Jul 8, 2004
  3. Bio-Hazard
    Bio-Hazard 2[H]4U
    2,312
    Jun 8, 2004
    I've got one coming already............ :D
  4. Erasmus354
    Erasmus354 [H]ardForum Junkie
    9,394
    Mar 12, 2004
    Lets hope it works...
  5. consumer9000
    consumer9000 Limp Gawd
    377
    Feb 24, 2005
    And yet another Swiftech part now made in China... :mad:
  6. el rolio
    el rolio 2[H]4U
    2,495
    Jul 8, 2004
    i kinda... want.. two.... to replace my maze4's.... which i both bought used. and that was good for me. saved a buncha cash.
    sigh. i can dream.
  7. penguin
    penguin 2[H]4U
    2,121
    Mar 11, 2003
    I dunno, I think it's kinda ugly.
  8. TehRoflcopter
    TehRoflcopter Gawd
    557
    Nov 5, 2005
    I see modding potential to make it look better if you're concerned about how it looks.
    It looks like it performs good though, as for the copper shavings and bead blasting, woo!
    This may be my new GPU cooler if it turns out good.
  9. DangerIsGo
    DangerIsGo 2[H]4U
    2,976
    Apr 16, 2005
    I think the stasis neptune is much better :D If its the same base used in the apogee, then blah. Id still want to see benchmarks but I want to see benchmarks between this one, stasis neptune 7800 and MAZE4 and fusion HL. Stop making these damn parts in china. Make them here and put the correct quality control as need be into them.
  10. jhego
    jhego [H]ard|Gawd
    1,412
    Jul 23, 2004
    nice, i was about to buy the MCW55.
  11. DFI Daishi
    DFI Daishi 2[H]4U
    2,839
    Feb 14, 2005
    great........another product with improved profit margins and possibly a reduction in quality.......just what users need.......
  12. DangerIsGo
    DangerIsGo 2[H]4U
    2,976
    Apr 16, 2005
    Exactly.
  13. kleox64
    kleox64 [H]ard|Gawd
    1,467
    Sep 21, 2004
    it looks kind of thin, IMO it will be quite restrictive probably more suited for low flow.
  14. Erasmus354
    9,394
    Mar 12, 2004
    By Swiftechs numbers it is less restrictive than the MCW55, which would make it not very restrictive.
  15. boof
    boof Limp Gawd
    170
    Dec 28, 2005
    Yay! Now we can have all of our blocks be based on the same baseplate. Apogee, new chipset block, and now this. O joy. :p
  16. Rithina
    Rithina n00b
    13
    Dec 27, 2005
    Any chances I can get this if I am not in US and any website take international order for this particular block? :)
  17. Budwise
    Budwise [H]ard|Gawd
    1,817
    Dec 7, 2004
    its the same thing as the MCW55 except a different top on it. The MCW55 already uses the same base as the Apogee since it is very unrestrictive. I doubt there would be any performance difference...
    EDIT: NM, it is the EXACT same thing as the MCW55 just with a different look, but slightly more pins.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  18. DFI Daishi
    DFI Daishi 2[H]4U
    2,839
    Feb 14, 2005
    the colour tags in yous sig don't work, and it helps if you not your specific country of origin when asking about international orders.
  19. Ominous Gamer
    Ominous Gamer Limp Gawd
    234
    Oct 24, 2005
    Why can't we go back to the old single slot watercooling days that we saw with the first custom 5800FX block? :(
  20. Budwise
    Budwise [H]ard|Gawd
    1,817
    Dec 7, 2004
    its another Apogee! Just like the Storm VS Apogee, the Storm is made in the US and the Apogee is imported from China i believe to make em cheaper for them. The same applies here, the MCW55 is made in the US, the MCW60 is not. Its Swiftech plan of trying to cut some corners to make another buck.
  21. CCUABIDExORxDIE
    CCUABIDExORxDIE 2[H]4U
    2,957
    Jan 30, 2005
    remember how the Apogee doesnt do great with chips that lack IHS's? thats exactly what im thinking is gonna happen with this block.
  22. Budwise
    Budwise [H]ard|Gawd
    1,817
    Dec 7, 2004
    i think it will perform on par with the MCW55, but should technically be more restrictive i would think.
  23. Rithina
    Rithina n00b
    13
    Dec 27, 2005
    Sorry about that. Thanks for the quick response. I staying in Singapore.
  24. DFI Daishi
    DFI Daishi 2[H]4U
    2,839
    Feb 14, 2005
    ah well, none of the stores that i have dealt with regularly ship to your area.
  25. Budwise
    Budwise [H]ard|Gawd
    1,817
    Dec 7, 2004
    too bad we'll prolly never see a review or a comparison test...
  26. aburgard
    aburgard Limp Gawd
    357
    Dec 28, 2005
    Sorry to say, but having products made overseas is by no way cutting corners anymore. China isn't cranking out crap anymore. It's less expensive, yes. That means it's also cheaper for YOU.
  27. Budwise
    Budwise [H]ard|Gawd
    1,817
    Dec 7, 2004
    The Apogee costs 40% less for Swiftech to make, BUT the Apex Ultra kit has by no means dropped in price.
    LMAO: I love this quote "The pin area is bead-blasted to guarantee a finish free of shavings" I cant wait for the people to start reporting shavings in the MCW60's now!
  28. DangerIsGo
    DangerIsGo 2[H]4U
    2,976
    Apr 16, 2005
    If you compare the apogee (china) vs storm (USA), the storms quality control is far superior...no shavings found in the pins and the molding isnt cut thin around the base as to risk leakage. If I could have gotten a storm, I would have.
  29. jetjaguar
    jetjaguar 2[H]4U
    2,538
    Jan 28, 2001
    i just received my storm from petras shop or wutever it is .. ended up getting the last one .. received it today ..
    i was thinking about getting 2 of these gpu coolers for my sli'd setup over the maze 4s .. but i guess i shouldnt ?
  30. Q-Ball23
    Q-Ball23 Limp Gawd
    157
    Sep 4, 2004
    So does anyone know if this will be better than the MCW55? I was just about to order 2 of them for my 7800 GTX's. Im glad I waitied!
  31. DFI Daishi
    DFI Daishi 2[H]4U
    2,839
    Feb 14, 2005
    swiftech's numbers say that it will. finding good independant reviews of GPU waterblocks is a bit of a challenge.
    i would look for MCW55 blocks on clearance sale, myself.
  32. Q-Ball23
    Q-Ball23 Limp Gawd
    157
    Sep 4, 2004
    Yeah not a bad idea either, but this way everything can match in my case. I got the storm, thinking about getting the mcw30 for my chipset, and 2 of these mcw 60's would look nice on those video cards :D
  33. Top Nurse
    Top Nurse [H]ardness Supreme
    7,269
    Nov 4, 2003
    I think they outsourced that part to a well known German watercooling outfit. ;)
    BTW, they bead blast the surface because it increases the thermal transference by increasing the micro surface area of the block. Plus it looks better to boot. If it has burrs that probably wouldn't get rid of them.
  34. consumer9000
    377
    Feb 24, 2005
    I just find it amusing that Swiftech thought they could get away with NOT beadblasting the Apogee to begin with. Any machinist will tell you that it's absurd not to deburr a part after it undergoes such trauma...
    While China has improved in quality, I still feel things made in the USA are generally better quality. Regardless, think of it this way: "What would you do if your job was outsourced?"
