The Lian Li Gallery
dannyd86
Well, the A05 thread disappeared so here it goes.
Got my A05-B today. Built it today. Love it!
Old Thermaltake Soprano DX and New Lian Li A05-B
I already got a 10x10 window for it, going on this weekend. Also going to put another exhaust fan on the top (blow hole)
My CPU temps dropped!!!!!! I still cant believe it.. Before my Q6600 used to run at an average of 55 degrees under load at 3.0GHz. I haven't seen it go over 48 degrees.
Nick_Leo
prob goin to order a PC-101 tomorrow. anyone have that case and what do ppl think of it?
amking
first real attempt at cable & noise management :eek:
specs:
abit ip35 pro
e6850
zalman 9500AT
2gb corsair ddr2-800 4-4-4-12
evga 640mb 8800 gts
x-fi xtremegamer
150gb raptor X
500gb seagate
corsair 520hx psu
sony nec/optiarc sata dvd burners
lian li pc-7b plus II case
yate loon 120mm fans
0ptional
Don't Trust Your Friends with Your Decanter
My V1100 is in the mail, expect pics by the end of the week (or so I hope :D).
Started out in a PC-65B that served me through a number of builds, both Water and Air cooled too, and then moved to a Shuttle for the first year of college, now moving back to ATX as I felt a little cramped in the Shuttle, and the V1100 seemed like a perfect fit for me!
NukeULater
I'm going to order a V2000B Plus II from performance-pcs.com soon. But first a quik Q, do they come with the floppy drive converter and optical drive door? I'm just wondering otherwise I'd order two right away.
Nick_Leo
Man after lookin in this section i have no clue witch lian li i want. i want one thats quite and also has good airflow and looks.
jag0
...if you want something that is roomy, light and with good air flow as well...then I'd suggest the PC-A05 (which is what I have.)
HardD99
Just installed some new 5.25" hard drive cages since i was running out of HD space. I still have a new psu i need to install (2nd psu, notice the new dual plate) and a Tuniq HSF. I know the cable management doesnt look very good, but if anyone can give me suggestions on how to hide 12 sata cables that go to different places on my mobo that would be awesome :)
Raikiri
Nice file (porn) server :p
What you can do to tidy it up a bit is cable tie the S-ata cables that go to the same place so that it looks like a single cable rather than loads. That IDE cable would be easy to hide a lot more than it already is. Great cases though ;)
Here's my G50 as it stands, need to get a few cutting discs though then I can cut some holes for cable management and for fitting 2 fillports. So far I've done the blowhole for the CPU rad and turned the HD bay 90 degrees / moved it back so I can fit a second rad for the graphics card :)
Rubbish
I think I'm in love with that case. :eek:
aggr1103
I fell in love with this case reading the ao5 thread. I had to have it. Still have some wire tidying to do but overall its been the highest quality case i've ever used.
Raikiri
Not the best of pictures, lighting is utter **** in my room so I had to use the flash... too lazy to get the tripod out.
I've done the holes for mounting the fillports and some for cable management.
Nick_Leo
i get my lian li v1200 plus II tomorrow from newegg. be nice seeing a nice box on my front porch after a long boring day of school. look for pics either tomorrow night or saturday.
Blue Fox
Nice blue fox. What are you doing with all of those hdds?
It's my media storage for the HTPC. Server doesn't get used for much more than that except if I'm encoding or rendering something (helps to have multiple processors). As for storage, it houses slightly over 4TB at the moment.
Nick_Leo
how do u turn around the hard drives? i try on my v1200 but if its in the other way the thing dont like down.
dearkook
When I removed the one hd rack in the bottom I moved the remaining one to allow for more room in the back. I had to widen two of the holes on the bottom to use all 4 bottom screws for the hd cage, I believe you just need a little extra room in the back of the hd cage to use them turned around.
dearkook
Evoic - Thanks! Those fans are Panaflo L1 Low Noise 120mm, I bought several 120mm fans and they were my favorite. Still waiting to receive my last one for the video card and replace that Yate Loon.
Nick_Leo
Finnaly got around to taking pics of my case.
^the orange switch is to turn on the lights.
now to where she sits.
and the lights.
0ptional
The whole setup:
The door opened:
A perspective shot of this beauty:
Ooh, is that an HR-03 Plus peeking through with a 120mm fan on my 8800GTS?:
Some internal shots:
iPhone pics, hehe, not the best, I'll see if I can get a hold of a real camera sometime.
Today I took the time to route around the wires a little better, but nothing is in the way of airflow at all, it pulls in from the back behind the CPU through the Tuniq Tower, and then rises up and goes out the side with a little help from the HR-03's fan. Maybe going to add a 120 on the side again but the side fan mount doesn't fit as well with the HR-03 installed.
jag0
Looks like those years paid off...that's mighty nice cable management.
Specs?
