The Lian Li Gallery
Here is my initial build, more soon.
By tirez at 2012-05-10
And then there were two...
Went to the NCIX warehouse sale and got a couple of things (can't believe no one picked these up, brand new unopened packages and over 50% off):
Brendan
Luring this thread for ideas on to fit full water on the PC-b10. Also realized i took a crappy pic when I reinstalled the h80 from RMA. Hopefully new job will push for full water when EK full cover block come out for the 670s. Also thinking about getting the fancy sleeved white cables from corsair.
Not a built rig but I haven't seen anyone post a PC-90 with a big board in it which is stupid so here it is:
I wish Lian-Li would make a mobo tray which actually fits behind the whole board for once...
Parts List:
Lain Li (PC-V354B) Aluminum MicroATX Case
MSI (890GXM-G65) AM3 890GX SATA III, USB 3.0, Micro ATX Mobo
AMD Phenom II X4 980 Black Edition Deneb (3.7GHz) Quad Core CPU
OCZ ModXStream Pro 600W Modular PSU
120GB Mushkin Enhanced Chronos Deluxe (MKNSSDCR120GB-DX) SSD
1TB WD Caviar Black 7,200 RPM Hard Drive
Corsair (CWCH60) H60 Liquid CPU Cooler
Rosewill (RNX-N300X) PCI Wireless Adapter
Sony Optiarc 24X DVD Burner
Corsair 16GB (4 x 4GB) DDR3 1600 RAM
(YET TO ADD) AMD Radeon 7970 Graphics
Hi guys!
Here is some pics of my new build. I was finally finished yesterday with it.
Enjoy!
Rizzt , that is the best designed water cooling system I have ever seen. This is far beyond clean. GREAT JOB!!!!! Your PC should be on the [H] front page for sure.
OMG!
That wasn't planed.. I am flattered! :eek:
I will post some more pic tomorrow, and share some secrets, just for you guys :D.
Just hold out :)
Hi guys!
Enjoy!
VERY nice build, Rizzt. I am proud to say that you have used some of the same design elements I'm incorporating into my current build, though mine is a hot wet mess compared to yours - there truly is no comparison. I plan to refer to your build as I work on completing mine; if I can get my final version half as clean as yours, I'll be thrilled. Seeing yours has definitely given me a basis to measure mine against. Thanks for setting the bar so high. (and grats on RROTD).
I used Bitspower Multi-link adapter to be able to use 12mm copper pipes.
you can see the O-rings inside the adapter on this pictures.
It is some builds out there that uses pipes. Not many, but some. This one inspired me the most.
But i wanted a small case and i already owned the LIAN-LI PC-V600FX.
Here was an early pic of the build
Hey guys check this out a Phobya XTREME QUAD 480 ( 4 x 120mm) Radiator at the top of my Lian Li PC-V354B case fits perfectly. And a Phobya XTREME 200 Radiator will fit in the front of case minus the HD cage removed. The cool thing about the 200mm rad is you can use 4 x 92mm fans will fit perfect with this setup just like the Quad 480 setup going on top. So now trying to decide if I should do 2 loops one for CPU (200mm rad) and the other for the GTX 690 (480 rad top).
Going to start cutting this case up in the morning along with allot of J.B Weld... Work log starting next weekend waiting for a new camera to arrive..
my Lian-li PC-A04 budget rig (general use) :eek:
sorry for those nasty finger prints.. :eek:
Thats a budget build for general use?!?! Very nice. I might just buy one now because your Pics, think WCing can be done nicely in there?
yes.. with a little modding at the lower 5" bay or just completely remove it, it can fit a dual 120 rad in the front..
i might do it soon.. if i have a budget for wc kit..
sample > > > http://a8.sphotos.ak.fbcdn.net/hphotos-ak-ash4/407690_296388697075980_1112895742_n.jpg
credits to the modder tantric from http://rignoobies.com/
Awesome thanks for the info! Cant fit a rad up top?
i think its not possible .. because it will be really close/touching the heat-sinks.. from what i know and measured the front is the only way to go..
you can also use some water coolers from antec or corsair at the back by using a 80mm to 120mm adaptors(you can make one using aluminum plates)..
Yeah but a watercooling loop is just so much better. And I want to watercool my GTX670.
First Post....
Very inspiring thread... I am just starting my rebuild of my older voodoo... Lian Li
I will be going in several stages... Those hard line water pipes look killer. Had not thought of that until now. I have a lot of reading to do out here.
Cheers,
Mikey
wow i had that same case and didn't have the patience to make it look like that wow
