The highly rated HP Pavilion Slimline PC thread
Ok,i decide make the hole today,because i have 2 cats and im scared if they move the fans, so here the pics of my rig (same size of the Xbox One) finished
And the temps after a match of Black Ops 2,reachs 70°C after 1 or 2 hours of gaming, its ok
im so happy the cut its horrible, but whatever,i finally done this project, the cost is about 670-700 dollars
AMD A8 3870K 3.0ghz
8GB RAM Kingston 1600Mhz
Biostar A55 MLV (the Gigabyte A75N USB3 cant be repaired and i bought this)
HP Slimline S5000 case (i need separate the power led and hd led, i use a precision knife)
Afox 7850 Low Profile
Shuttle PC63J 500 watts 80 Plus
No DVD drive
500Gb HDDD
Chry
AMD A8 3870K 3.0ghz
No DVD drive
500Gb HDDD
This is brilliant, powerhouse! I'm guessing the PSU don't get much cooling though?
The PSU have a little 50mm fan and gets airflow from the top of the case,in this zone
helps a lot to keep fresh the PSU
Sudhakar2k
AMD A8 3870K 3.0ghz
No DVD drive
500Gb HDDD
Where did you get the AFOX 7850 low profile card and how did you fit in the $700 budget?
I have done some cursory searches in this threads to see how many have swapped a totally different motherboard into a Slimline case, but have not found what I'm looking for.
The title says it all. ASUS M5A78L-M/USB3 in a Slimline case. The main issue is getting a powerful enough supply for an A10 chip (90W?) in the box without running in to any of the components on the mobo.
  1. Any links to anyone's build who has swapped a non-HP motherboard into a Slimline case ?
  2. Is there somewhere in the thread/forum that shows the differences between the various Slimline cases ?
In s5000 cases you can install a Micro ATX motherboard, im using Biostar A55MLV Micro atx in that case,
But if is a hp slimline s3000 /s7600 series, only allows ITX cases
The S5000 uses TFX power supplies
The s3000/s7600 uses flex power supplies
The only issue to use thios cases,is the front panel connector (power/led/hdd led)
as you can see, the conector is unified, you cannot split it , this is a trouble if you motherboard have a different position for the connectors,i use a precision knife to separate the pins, i reccomend you do it slowly, i need 2 hours to finish the cut, but works fine, or you can buy in ebay a front panel extension
That is exactly the kind of info I am looking for !
THANKS !
Sudhakar2k
It took me about 15 minutes to seperate pins from the connector. I actually used a needle to do it, but yes you must be careful. All you need to do is de-latch the plastic holding the wires in place. One other note, lining up the pins with the new motherboard was a trial and error thing for those that just had an empty case lying around. You could damage your motherboard if you connect the wrong pins.
Sudhakar2k
I bought a HP slimline s5000 case in 2012 off ebay, and just built a new computer out of it this month. I used a ASUS Z87 board, and Seasonic TFX power supply. Its an energy-efficient high end desktop PC. More details of my build will follow as I am happy with the end result.
Sudhakar2k
www.ebay.com/itm/New-OEM-Shuttle-PC63J-500W-80-PLUS-Bronze-ATX-12V-Power-Supply-/380440556016?
i add the link for the PSU, i cant found a better deal, fit in S5000 case perfectly, in S3000 theorically fit
If you are looking for a power supply for S5000 cases you should choose one of the flowing. They are cheaper, better, and run cooler than the one you linked too.
http://www.newegg.com/Product/Produ...8000&IsNodeId=1&name=80 PLUS BRONZE Certified
The only reason to go with Shuttle is if you have the low profile 7850.
Sure,i think im not the only one who's planning put a 7850 LP (someone ask me for the card), im posting if someone are looking this PSU at the best price
This PSU runs quiet and cooler, i tried a 1U PSU before and there no comparation,Shuttle make a good work, the fan isnt loud (i tested before i put the card)
Sudhakar2k
Big news on graphics front. Nvidia just released their first Maxwell based Cards. There are new high-end low profile, highly efficient cards coming on this technology, the Nvidia GeforceGTX 750 ($120) and Nvidia GeforceGTX 750 Ti ($150). The latter card has the performance of the Radeon HD 7850 in the thermal profile of the 7750. Idle power use for 4-5 W, max TDP 60W. They run purely on PCI-E slot power, but some of them come with 6-pin connectors for optional overclocking. Already two low profile cards have been announced by Galaxy. So if you want a high end gaming slimline, it will now be possible at low power consumption and an affordable price.
some links:
Galaxy GeForce GTX750 OC 1GB
Galaxy GeForce GTX750 Ti OC 2GB
Performance of GTX 750 Ti compared to Radeon HD 7850
some links:
Thats cool ,personally i dont like that cooler (i bought Zotac GTX 650 LP,exactly the same model like this 2) and always reach 85°C in my old S3000,i hope a better temperatures with the new architecture ,if the TDP is 60 watts, can run in 350 watts PSU
So,im waiting for Afox response, if they planning retain the title of the most powerfull LP Card, a hypothetical R9 270X underclocked to keep the 1 pin connection would be announced.
Personally i keep my 7850 LP for Mantle, with the final drivers BF4 can be played in Ultra around 40 FPS and the future games with this API recieve a boost,but im happy for Nvidia to introduce a new chip to make a powerfull LP card, GTX 650 LP sucks so bad.
cbinvb
some links:
Wait, those dont seem to me like "low profile". 140mm wide is like 5.5" i thought low profile to meant like 3-4 inches wide.
Sudhakar2k
No they are low profile. The picture does not show the low profile bracket, in which case you will lose the VGA port. I'm still hoping for more low profile cards, as I want a single slot card that has HDMI, Displayport, and DVI like Sapphire 7750.
Chry
Low profile option for those looking for a passive cool. Expect would be a neat fit in a s3000 case. Danger temps though..?
r9 240 Core edition
Chry
That board will be too big for the s3000 variant cases.
You may have more luck(room) in a s5000 variant case.
Related but also separately here are some disassembly instructions for the s5000 case
r9 240 Core edition
I dont recomend passive cooling cards,more if you use it in that case, because the airflow doesnt exists and the heat stays inside
MSI model looks good
and the noise isnt audible
Chry
Yes , you are right.
And the MSI does look good.
This is better than the 7750 right?
For those in the UK:
2GB version at £110 ($185)
http://www.overclockers.co.uk/showproduct.php?prodid=GX-058-KF (will need LP bracket separately (annoyingly))
A lot better,the GTX 750ti is a bit worse than 7850LP ,but run cool and quiet, i saw some reviews from Google, and the temps stays in 60°C, thats very nice
For example im having some trouble to keep safe temps with my 7850, this days the weather was very hot, 30°C+ to be clear , and i get 2 or 3 crashes for overheating (my card crashes if the temperatures reach more than 83°C).
A need to improve to put another fan, right now im getting 76°C palying Titanfall on High Settings.
bcarter
I've read through some of the pages, and have found a great deal of information. I have a S3713W that I'm wanting to re-purpose as a HTPC, with some gaming capabilities. I have consoles for heavy gaming, for the time being. Going to build a gaming rig later. I have a few questions and need some opinions on my build.
Here are the specs for my slimeline.
http://h20565.www2.hp.com/portal/si...ac.admitted=1397869928819.876444892.492883150
Motherboard: I plan on keeping the factory MB.
CPU: Has the AMD Atholon X2 4450e; should I search for a faster CPU? The AMD Athlon 64 X2 5600+ looks to be the most powerful one by spec.
Memory: I'm upgrading to (2x2)4gb of DDR2 800mhz of ram.
Video: Can the onboard graphics handle the HTPC use? If not this may lead me to switching all these components to another case. :( Unless there is a cost effective solution for this application, and may as well add HDMI. The only gaming this PC will see is most likely the Sims 3. It's primary use will be to play BlueRay and stream video.
Sound: From my search the onboard sound should be sufficient.
Hard Drive: I'm going with a 1-2tb hdd for storage and a ssd for boot-up. What size ssd should I get for these particular needs? I have seen people go with anything from 32gb to 128gb.
Disc Drive: Pioneer or LG Blue Ray drive
Case: Staying the same or switching to a Betfenix Prodigy
PSU: If using the Slimline case I have found these on Ebay. Are they a good choice?
http://www.ebay.com/itm/HP-Pavilion...t=LH_DefaultDomain_0&var=&hash=item417e26f1ce
Operatinng System: Going with a version of windows with XMBC most likely.
Other than the listed above components; there will be as much effective cooling as possible.
artG8345
I bought the hardware for a miniITX unit: all the hardware seems to operate correctly. When I go to load Linux (Ubuntu) it just hangs. I've tried other steps, such as to use GParted to prepare any basic partitions...also hangs. When I am using a startup disk (either DVD or USB stick) then I get the starting Ubuntu logo but as it starts to load I get to a blinking underscore and it just stays there. I suppose I'm not knowledgeable enough about the starting steps for this...these steps worked for me on a basic desktop so I'm not sure what is the difference?
Art
Hardware:
HP Asus MOCA-AR Calcite-GL8E Desktop Motherboard MINI-ITX 5188-5155 Calcite 6502
Intel Core 2 Duo T7280
2x1GM RAM in the 2 x 200-pin SO-DIMM sockets
550W ATX power with adapter to fit the 20pin connector
photos:
artG8345
Art
Hardware:
photos:
http://www.zitollc.com/HPAsusMocaARCalciteGL8EminiITX51885155.JPG
http://www.zitollc.com/MotherbaordSpec.JPG
http://www.zitollc.com/IntelChip.JPG
http://www.zitollc.com/ATXpower.JPG
http://www.zitollc.com/PowerAdaptor.JPG
http://www.zitollc.com/RAM.JPG
Try with the 7750 Low Porfile,works with a 250-300 watts PSU, and run the last games with decent quality and isnt expensive
www.newegg.com/Product/Product.aspx?Item=N82E16814161418
SSD isnt important at this case, but if you wish a faster boot, use a 64gb SSD only for OS, the best drives are: Samsung 840, Plextor M5,Kingston SSD now,etc
Dont buy that PSU, its loud and cheap
Buy this PSU www.newegg.com/Product/Product.aspx?Item=N82E16817151116
Chry
Art
Can you reach BIOS (first)?
I would try to isolate the fault as usual to a particular compnent by adding removing with ones you know are working. Also memtest to check RAM if you haven't already?
bcarter
I appreciate the information. The SSD was only recommended on all the htpc builds that I have been researching; I personally haven't had an issue with the boot up time.
Chry
Have you looked in the Slimline case? If you are planning to stay in it please note you will struggle to fit the additional* SSD in (or at least it needs some thought). :)
Consider a Hybrid drive?
*additional to 3.5" HDD and ODD
AirCool
The 3 and 5 series slimline case has a useless drive bay for HP Pocket Media Drive. Removing it will give room for SSD. You should make sure you have spare SATA port and power though.
I second that SSD isn't very useful for an HTPC. I had one. But for gaming, I think it would be useful.
bcarter
That's the location that I had planned on using, but if it isn't needed for this application, then I'll save the money for other projects.
I appreciate everyone's help. The only thing I have left to decide, is whether or not to keep the factory case.
