The [H]ardForum Perpetual Freebies Thread
Shyster got the better of me at a garage sale, inner carton was upside down and the drive was loosely inside so it fell out and I ended up paying for a busted NVME (thankfully not much). Doubt anyone will want this but if someone has the tools to pull the chips and wants something to play with it's yours. I figure it's destined for the trash though.
Taken.
So they had it in a way where u could not verify or check the nvme inside the carton?
It wasn't in the insert in the tray and fell out when I was taking it out to inspect it. The missing chunk was still attached at the time, cracked, but I don't know where it's gone off to now. Foolish on my part not to ask them to handle it but a lesson learned.
Anyone have a couple nvme ssd’s? I wanna load up a couple configs for my router and keep it as a backup since my router keeps having a kernel panic. Trying to determine if it’s OS or hardware related.
Still looking for at least 2 preferably 32GB or larger nvme for this.
More cleaning - quote via PirateShip (USPS). Please provide ZIP.
I have some pick-up only items for Tucson, AZ locals - PM as it is an ongoing list.
Mostly everything is gone. I may have more stuff to list next week.
CRUCIALUnbuffered DIMM (CT8GG4DFS8213)16GB (2x8GB DDR4 2133) Claimed by: CAD4466HK
OTHER
QNAPTS-230 SATA TRAY x2SATA Tray
QNAPTS-230 Power Adapter (OEM)Power Adapter
QNAPTS-230 Power Adapter (Aftermarket)Power Adapter (Aftermarket)
I could use all that qnap stuff if you still have it. Shipping would be to 94010. Thank you!
This maybe pushing the "Freebie" theory but I'll ask anyway LoL!
Does anyone have a Lenovo ThinkCentre Tiny DVD Super Multi Drive Kit 4XA0K93942 00XD342? I don't need the metal bracket nor the drive I just want the case as I had one and I actually liked it VS those other cheap eBay models but alas I lost it in my move AKA my life sucks
Thanks
Looking for a basic 512GB or 1TB M.2 NVMe SSD for a Ubiquiti UCG-Fiber that I will be picking up in the coming days. Only requirement is that it is single sided, but I think most are
is a usb caddy with a laptop style drive on a steel cage*, you just plug it in.
View attachment 737021View attachment 737022
*i think the cage is for vesa mounting a nuc/mini pc for like POS terminals
Yes the cage is for the "M93 Tiny" or whatever Lenovo calls their USFF PCS the cage is removable from the plastic drive caddy
I used to have one I just wanted the "caddy" as frankly most other external Slimline SATA external cases are trash I am going to put my LG BU40N in it
Haswellbeast is a good seller and knows how to protect a package!
That has got to be the hottest running 2500k I have ever seen at idle! But it works and that's all I care about, don't have a board to test the Ryzen yet, but I'm not worried.
Would buy from that dude again!
Does anyone have a dead or malfunctioning reference Quadro FX 3500 / GeForce 7900 GS, GT, or 7950 GT with a working stock heatsink/fan? I'm looking to convert my XFX 7950 GT passive to stock cooling if I don't sell it. I'd rather avoid spending $25 for a Quadro FX 3500 to shuck two just for the HSFs. Will pay shipping... Please PM me directly as I don't regularily watch this thread if you have a HSF for me!
EDIT: the stock HSF I'm looking for looks as shown in the pic attached below:
The Quadro branded identical model HSFs will do as well, but I'd prefer the stock GeForce ones. This will help me avoid having to buy two dead 7900 GSs or 7900/7950 GTs or functional Quadro FX 3500s and shuck them for their coolers. Hopefully one of you out there can help, so here's my request in a bottle for your mind one time.
I know this is a long shot, but asking anyway...
I am looking for the power cables for an automotive 150 watt DC to DC power supply. It uses 20 pin ATX + 8 Pin power supply cables. It is from 2004, so it uses the old ATX motherboard connection type. Power supply is made by Opus Solutions (PSU model SFX-1215). I can't believe I lost the original cables.
Product info with pictures of cables that I am looking for: https://www.zombiecomponents.com/store/opus-solutions-150w-dc-dc-atx-power-supply-sfx-1215/
Stock photo with the original cables that I am looking for:
My Opus PSU:
My Opus PSU:
View attachment 739971View attachment 739970
Could you use a 24-pin and just let the extra 4 pins hang off the end?
The hole patterns match up perfectly with 20-pin ATX and 8-pin EPS12V.
The other end plugs into what looks to be an ATX motherboard so I would assume the 20-pin is standard. It looks like 24pin to 20+4pin cables are easy to get a hold of. If you have to get rid of 4 pins then some flush cutters would probably do the trick.
The 8pin looks like it breaks out to 4pin molex and something else. You might need to just make one yourself by probing the power supply's 8pin for 12V, 5V, and ground.
Good luck!
I always have the oddest things...
Todays oddity....my script changed and both eyes use the same now, so this extra box I have no use for (Im nearsighted)
CooperVision contacts
MyDay daily disposable
multifocal
sealed box, 90 lenses
SPH -3.25
BC 8.4
DIA 14.2
ADD MED
Will post pics shortly, just pay shipping
multifocal
SPH -3.25
BC 8.4
DIA 14.2
ADD MED
I might be able to use these if there are no takers. Just need to verify my prescription.
Maybe a longshot here, but looking for some hardware from the same time period as my first proper gaming PC back around 2007. Does anyone have LGA775 hardware they are willing to part with? I'm happy to pay shipping plus a bit extra especially for tested/working hardware. I kept some of my original parts over the years (Antec 300 case, 2x EVGA 8800 GTS 640mb, ODD/HDD, sound card), I just new these few to put everything back together. I'd love any of the following parts:
  1. Core 2 Quad chip (the OG Q6600 would be perfect) - found a Q6600
  2. ATX motherboard that supports SLI (I had an EVGA 680i but I'm not picky) - found a XFX 750i SLI
  3. DDR2 kit (2x2gb or 4x2gb 800mhz would be awesome) - found a PNY 4x2gb DDR2 1066mhz kit
  4. LGA775 tower cooler like a Hyper 212 or TRUE - found a Zalman CNPS9000
  5. A WD VelociRaptor 10k rpm drive or pair for RAID0 (because the era before cheap SSD's was fun, right?) - found a couple small SATA SSD's instead
EDIT: removed items pending trade/swap, found what I need.
I have a few pieces of newer hardware I could offer in trade which might be more useful to you than me: a GT 1030 LP card, a Chinese DTX H81 motherboard w/ i5 4570T, AXP90-X53 cooler, 16gb DDR3, and 240gb NVMe, an AXP-120-X67 black ARGB cooler with all mounting hardware, an Apevia 500w FlexATX modular PSU with cables, an ASRock B660m ITX WiFi motherboard, a 32gb DDR4 3600mhz kit. I even have a Viewsonic 24" 1080p 180hz IPS with box but might be expensive to ship. Overall lots of random bits and bobs from old projects I don't use anymore that I can barter with.
Unfortunately, 775 hardware is starting to go up in value, the only cheap ones you will find are OEM ones. Relieving though is that the CPUs are cheap, especially the q6600 things.
I don't have what you are asking for but I have some things that are adjacent if you would like:
1. I have an E6400, which is a Core 2 Duo, if that interests you
2. I have an LGA 775 motherboard, but it doesn't support SLI unfortunately
3. I have a Patriot PC2-6400 kit (2x2GB) and also 2 more 2GB PC2-6400 sticks that aren't matched (1 crucial, 1 hynix)
4. I have a Zalman CNPS9000 tower cooler
5. No velociraptors, unfortunately, but I have plenty of 128gb SATA SSDs which let's be honest even if you are making a retro build you still want a SSD lol
You're right, I definitely see that on eBay. That's why I'm bartering some significantly newer hardware to see if I can shake anything loose from people here rather than roll the dice on eBay.
Sending you a PM on the Patriot kit, the Zalman (what a throwback, loved this cooler), and the SSD. Thanks!
