The [H]ardForum Perpetual Freebies Thread
I need one of two solutions to repair a friend's PC...
--any old motherboard with SATA.
or
--PCI SATA card
I also have tons of FREE old stuff available in my FS/FT thread.
Have:
DVI Cable 6FT New from a Dell Monitor
Apple Firewire Cable 4P-6P
Apple iMac Power Cord (See through you can see the 3 wires inside of the cord made for the iMac G3 bit will work with any item with the standard IEC Power Input)
2 X Floppy disk drives + Several disks (All are not guaranteed to work)
IDE/SATA to usb 2.0 Adapter Only the Adapter no power supply as I am keeping that for myself (Sorry!)
Wanted:
VGA Splitter (Male 15pin DSUB to 2 x Female 15 Pin DSUB)
VGA Cable 6FT or more (Found!)
Small IDE HDD 4+GB or more but not more then 120GB (this is for an old machine and the maxium is 137GB Due to the LBA Restriction (I think) (Found!)
DVD-Rom/CD-RW All in one drive preferred
2.5" PATA/IDE hard drive <20GB 5400RPM is preferred but any will do Thanks
I could use a set of 3.5inch mounting rails if anyone has some handy. I swear I've probably pitched 30 of those things over the years. :p
Just looking for an IDE ribbon cabel to go from my motherboard to two IDE drives... LMK!
have a fan or two (bit noisy but they work!)
I'll go through my stuff and see what i have. I'm bound to have one left from one of my builds
Will this do you
Looking for a Dell DA-1 power supply. (for a Dell SX260). I have some SCSI cables/controllers and old video cards.
wjogert, yhpm.
so like, 2.5" to 3.5" rails or 3.5" to 5.25"? :p I have both, not sure if the holes line up properly, but thats easily solved if you have a drill. ;)
NERVEGRINDER'S FREEBIE THREAD
- CONTACT ME BY PM ONLY and let me know what your zip code is.
- I ship to the 50 US states ONLY.
- I accept usps money order, cash through snail mail, or non-cc paypal.
- I do not exchange heat for freebies, sorry folks.
LOOKING FOR THIS STUFF
Anyone got an old box of l33t scsi gear they dont use? Im making a retro pc and could use some scsi goodness. :)
- scsi dvd-rom drives
- adaptec 29160/39160 scsi card (not low profile, I need the 50pin narrow connector)
- SCA scsi adapter (68pin+4pin molex --- > 80pin SCA)
- external scsi cable (50 pin centronics and/or 68pin lvd)
- ESD bags for motherboards (large sized ones)
- round ata/ide cable that is 18-22 inches long with 2 connectors only (1 device and 1 port connection)
- Pentium 3 (P3) socket 370 motherboard, preferably server class (tyan, supermicro) that can take ECC/REG memory
- bios battery for powermac g4
- wifi/airport 802.1b card for powermac (same card used in ibook)
GIVING AWAY THIS STUFF
1 x Syntax SV266AD Socket A/462 motherboard + i/o shield (no physical damage, pulled from system and as is, untested).
1 x S3 virge AGP video card (no physical damage, pulled from system and as is, untested).
1 x Quantum 10GB IDE Hard drive (tested clean, no bad sectors)
2 x Seagate Medalist 4.5GB ST34520N SCSI hard drive (tested clean, no bad sectors)
1 x Seagate Barracuda 4.5GB ST34572W SCSI hard drive (tested with <1% bad sectors)
1 x Adaptec 2930 PCI scsi card for Apple/MAC systems (AHA-2930CU)
1 x samsung SCH-A650 cell phone w/ battery and charger (for verizon)
1 x LG vx3400 cell phone w battery only (for verizon)
1 x ATI AIW 9800 Pro (as is, sold for parts only as it artifacts heavily).
3 x 128MB PC133 sdram
1 x 128MB PC100 sdram
1 x 64MB PC133 sdram
1 x IOLO search and recover software w/ serial (new)
1 x 52x Aopen cd-rom drive (IDE)
1 x Sony cd-rom drive (IDE)
1 x 3com 56K Global Modem PC Card (for laptop) w/ dongle
1 x Xircom 56K Modem PC Card (for laptop) with cable
1 X 100MB IOMEGA ZIP DRIVE
1 x Five for Fighting Music Video DVD (Easy Tonight & Superman)
1 x 6ft VGA extension cable
1 x 6ft Belkin IEEE1284 printer cable (gray)
3 x PS2 mouse (2 are microsoft, 1 compaq, all have rubber ball)
MANY x CD spindles, various size that hold between 20-100 discs. LMK what you need
STUFF I'VE GIVEN AWAY
1 x Quantum 10.2AT IDE Hard Drive (10GB) gone to JEDI
1 x LiteOn 40X CDRW (LTR-40125S) gone to ghouldini
1 x Apple 6x dvd-rom drive (oem from powermac g4) gone to santuitman
1 x 3com USB Ethernet 10/100 Adapter w/cable and floppy driver gone to santuitman
1 x 3com Etherlink 10MB PC Card (for laptop) w/ dongle gone to dyesa
2 x 10/100 PCI NIC gone to dyesa
1 x Vantec Tornado Fan gone to dyesa
1 x HP JetDirect EX Plus 10Base-T print server (J2591A) w/ ac plug gone to TechKnight
2 X 80MM ASPIRE FANS (NEW) gone to hube235
3 x 10/100 PCI nics gone to kilnsea
1 x Family Guy Dvd (season 2, disc 2, episodes 1-7) gone to KurskKnyaz
1 x Mid-Tower ATX case with 350W PSU gone to Ray06492
1 x Tony Hawk's Underground 2 PC GAME gone to moks78
4 x 3com 10/100 PCI nics gone to BigBadBiologist
1 x Diamond Stealth S540 16MB AGP Video card (passive hs) gone to Skrying
1 x Ipod Nano Suede Protector Case (New, Original from box, white) gone to RKS
2 x 50 Disc Spindle (empty black spindles for media storage only) gone to ximhkx
1 x 3com 10mb NIC PC Card gone to khurios2000
1 x 3com 56k Modem PC Card gone to khurios2000
1 x ADDA 80mm fan (OEM pull from Lian-Li case, high speed) gone to Drakula
1 x NIDEC 80mm fan (Has a propriety 2pin header, very loud, pushes a lot of air) gone to Drakula
1 x Sparkle 400W FSP400-60GN PSU (ultra quiet w/ modified Panaflo L1A fan) gone to Flash1969
1 x ADDA 80mm fan (OEM pull from Lian-Li case, low speed) gone to JDMnAR1
1 x ADDA 80mm fan (OEM pull from Lian-Li case, high speed) 1 gone to NoMercyGTP
1 x MUSHKIN 128MB PC133 (Single Sided) gone to liveordie
1 x SAMSUNG 128MB PC66 (Dual Sided) gone to dasman2
2 x 64MB PC100 (single sided) gone to dasman2
1 x LG Car Charger gone to JDMnAR1
1 x LG Home Wall Charger gone to JDMnAR1
1 x CCFL with 2 x 12&#8221; lights (purplish/blue color, comes with all parts) gone to NoMercyGTP
1 x 2 port USB Bracket (connects external usb devices to mobo&#8217;s usb header) gone to NoMercyGTP
1 x Creative Muvo Ear Buds (New, Original from box) gone to morkus64
1 x Ipod Nano Ear Buds with 2 Sets of foam replacements (New, Original from box) gone to DLBlank
1 x P3 733MHZ CPU gone to
1 x 48X CDROM gone to hube235
1 x 48X CDROM gone to smartmoney
2 x 10/100 PCI NICS both gone to Kaervak
1 x floppy drive gone to Carnage4
1 x floppy drive gone to smartmoney
1 x ati 2mb pci video card gone to txlonghorn
1 x matrox 2mb pci video card gone to txlonghorn
1 x novell suse linux technical resource kit gone to
2 x pentium pro heatsink/fan combo gone to Gillbot
1 x lot of simm memory gone to Gillbot
1 x lot of empty cd spindles gone to dubb
1 x 56k internal pci modem gone to trevinom
MY HEATWARE
MY HEATWARE
I'm looking for the following:
some thermal paste
sata cables
I have the following freebies. just pay the mailing costs from zip 30238
3 pci lan cards
3 older tv turner cards
1 older sound card
2 older ati agp vid cards-3d rage pro 2x/3d rage pro turbo
1 cnr modem
1 promise ultra66 controller card
pm or email on model of the cards
Have:
Wanted:
I have a couple 20GB IDE 3.5in hard drives and a 20?GB IDE 2.5in hard drive. Also have a VGA splitter somewhere (as in 1vid card, 2 monitors) and a 6+ft vga cable if u still need it.
U lookin for a desktop DVD/CDRW combo drive or a laptop combo drive? Not sure If I have that...
Let me know if you're still looking for this stuff
Need northbridge heatsink for ABIT IC7-G Max2. Fan does not have to work. or any other northbridge heatsink that would work.
also. need stock P4 S478 heatsink. I have a fan but need just the sink.
thanks
Interesting... since I'm pretty sure I have the heat sink with no fan!! :p
Can't count the number of times I told myself to just throw it out.
Now I can't remember if I ever did or not.
Lemme check tonight, and I'll PM if it's still there.
recieved lots of replies on FS/T. thanks everyone! ended up getting a Northbidge heatsink, P4 heatsink+ fan, and a 2.0Ghz cpu FOR $3+SHIPPING ended sending $12.
Hi,
I am looking for 7 to 10 DVI to VGA adapters.
I am part of a student organization at our university which refurbishes PCs that are then donated to non-profit organizations in the Philadelphia Area. We recently got a lot of decommissioned DVI-only workstations, but most of the monitors that we have are VGA. I didn't have enough at home for all the systems
I'd prefer to get a lot of them from one or two people. I will gladly pay all shipping-related costs, but let me know if you have an alternate asking price.
Thanks!
must take 775 single core. cpu and be from Canada trying to get one for poor family going again.
Hi,
Thanks!
I have ONE.
Sorry that it's not more so it can be a bulk deal, but I doubt shipping would be more than $3 via first class. (Cardboarded up in an envelope) If you still need at least one more, let me know. It's your standard DB15 VGA Female to DVI-I Male adapter with 4 pins around the keypin.
I have ONE.
Thanks for the offer, but as you stated, I'm really looking for lots of 4-5, if not a whole lot of 10. I am willing to pay more than shipping if necessary. It'll save everyone time and effort, since I don't want to bother someone to ship out one thing.
Keep in mind a set of 10, brand new, is $23 shipped to your location (from your heatware) from monoprice.com. ;)
I may have a few, but I most likely gave them all away already. I'll double check and PM you if I find around 4 or more.
Thanks, that's exactly what I was thinking (I was checking monoprice/Ebay for lots). It's not a huge priority at the moment, and will most likely post a WTB thread later for this and other items we need to get these systems out the door.
Hi,
I am looking for a working PCI videocard with a S-video output. In addition, i have a P4 2.8ghz s775 up for grabs, haven't checked it it works though.
Thanks,
Jinx
EDIT: P4 is gone, may have more in a month will update later
Hello,
What I'm looking for
- s775 or s939 board that supports DDR2 (integrated graphics would be great)
- s775 or s939 cpu
- Any ddr2 ram
- IDE hdd (something like 40Gb would be good)
- Low end power supply (something around 280W would be enough)
- Might also be looking for 2x KTT8000/256 laptop ram
I'm not in any urge, this is simply for a low end server that I could use.
What I have
- ATI Rage IIC 4Mb agp video card
- Crystal CX4235-XQ3 sound card
- 128Mb PC100 sdram
- LNE100TX Linksys ethernet pci card
- DFE-530TX D-link ethernet pci card
- DFE-690TXD D-link laptop ethernet card
- Dual phone lines pci card
- A bunch of sata cables
- Motorola CyberSURFR Wave cable modem
- Webstar DPX100 cable modem
- Usb Logitech quickcam messenger (Webcam)
FYI I'm located in Canada (shouldn't really change the shipping price for such small items but just wanted to mention it).
Please keep in mind that some of stuff is old and that I cannot test it.
Thank you :)
Hi Everyone,
I'm looking for a heat sink that fits a socket A (462) motherboard and supports up to a Athlon XP 3200+ processor. It can be one of the heatsinks that requires mounting holes.
What I have for free:
Pentium III 500MHz Slot A processor pulled from a Dell
56K Modems, both ISA and PCI
simple PCI sound card
Might be a long shot, but does anyone have a Phenom 1 HSF? You know, the one with four heat pipes?
Thanks.
Well, I gave a desktop PCI b/g WiFi adapter away in this thread a few months ago...and now it turns out I am in actually in desperate need of one. Odd how things work, huh? :p Anyone?
Anyone have a spare LGA 775 CPU Heatsink Fan (I need it to support an 84WTDP P4 2.8GHZ) any kind is fine as long as it supports the Prescott core 84WTDP my cheap OEM cooler is not cutting it and the comp shuts down in 10 seconds because of CPU Overheat
Thanks
Did u clean out ur current heatsink or use new thermal paste?
Giving away:
Gigabit adapters...
Airlink - AGIGA32PCI
CompUSa - No model
Hard Drives:
IDE
Western Digital 40GB - PENDING
2x Seagate 7200.7 200GB - PENDING
SATA
Seagate 7200.7 160GB - PENDING
Hitachi Deskstar 80GB - PENDING
