The [H]ardForum Perpetual Freebies Thread
Some free game-related codes from Verizon FiOS - I don't play any of these, so am giving them away.
If you have a FiOS account, you should have the same offers. Check this link for more info:
https://www.verizon.com/home/promo/offers-fios1
World of Warships: Win with in-game loot, 4 months of Premium Account status and two premium warships (USS Albany and the USS Arizona).
We're sending you to World of Warships to redeem $75 of in game content.
Redeem by: MAY 31, 2021
Redemption Code: VZFR-3CAM3-XGNA3
Roblox
: Treat yourself to a 500 Robux Digital Gift Card. Spend it on new looks for your avatar, in-game perks and more
JS45F-UYGHF-GETD6
Redeem the offer by going to https://www.roblox.com/redeem
Your 60 days access offer requires that:
Redeem by 12.31.20
Pokemon Go:
Verizon Trainers get a Premium Battle Pass, two incense and 65 Poké Balls
Here is your game code. You'll need to copy and paste the code to redeem your offer.
3YHAHD3K8QFZD
iOS and Android users can redeem
https://rewards.nianticlabs.com/pokemongo/signin
Redeem by 12.31.20
I’ll take the roblox code
noctua nt-h2 paste, 80mm fan, usb to DVI adapter, some power supply adapter (think for an HP), sabrent sata m.2 drive to 2.5" sata enclosure, 5x 120mm thermaltake riing rgb fans with broken rgb (some red, some whiteish) with required controller (which now only controls speed and only has 3 fan outputs), a couple heatsinks (one which I got in this thread) a thermalright and a bequiet. The bequiet is all bent from shipping damage and trying to bend it back (really bent), and they both have a haugpauge of hardware to make them work since some was missing. Will include some various screws but you have to be creative to mount them to am4 (which I did). Comes with 2 135mm silent wings 3 fans. Mining stuff. Take as much as you want, I have regional and flat rate boxes so send me a PM for pricing but $15 per box likely. All of it probably fits in 2 boxes. "500 watt" turbolink atx power supply. Piece of junk I got in some computer and used it for a spare, never actually had any issues with it. Get this stuff off my desk.
still have a bunch of this stuff available! Hate to toss it.
Longshot.. But does anyone have an old 5.25 floppy drive? Working on an old 286 and the drive is dead.
Longshot.. But does anyone have an old 5.25 sloppy drive? Working on an old 286 and the drive is dead.
You'd have better luck over at vcfed.org. Any old 5¼ drive you find is going to have issues at this point, you're better off trying to fix the one you have. There are an eye watering number of different standards for both the drives AND the media, many of which are not compatible with each other. The most common formats are 360k, 720k and 1.2mb, but there are dozens in between with different bit rates, track densities, single or double sided, and even the file system itself.
Assuming you have a later dumb floppy drive and not an earlier hideously complex one, there's really not a lot that can go wrong with them. Leaking electrolytics or shorted tantalums are a common problem, as are faults external to the drive. There could be a fault in the disk controller, cabling, motherboard or even power supply.
I've had really good luck with Ebay for 5.25" drives for my retro PC's. Of the last 4 that I purchased, all have worked just fine. If you want to go the alternative route, you can use a Gotek floppy emulator in place of the real floppy drive. The Gotek also makes getting information/program/games to and from the system 10x easier since you can just use a modern computer to transfer the files.
K&N 33-2247..fits most V8 Ram trucks from 2002 to 2020
https://www.knfilters.com/33-2247-replacement-air-filter
shipping will be whatever a flatrate box cost...maybe $12-$15 tops
JK Wrangler wheel spacers....a set of 4 with lug nuts included...also included is a spare tire adapter to mount deep offset wheels on the spare tire carrier if you need it....these are dirty but Ill clean them before sipping..
Im guessing 20 bucks tops to ship them.
Free, you pay shipping from 95209 (CA). All tested to be working but could arrive DOA.
Antec HCG-400 PSU does not have pci-e 6+2 but does have pci-e 6 pin
5 used black sata dvd burners
--- GONE ---
Netgear XAV5602 ---> GONE to Triolent
2 used stock Intel g3258 hsf lga 1150 ---> GONE to legcramp
1 new stock intel 4770k hsf ---> GONE to legcramp
2 used cooler master 212 w/ lga 1150 ---> GONE to legcramp
Antec Earthwatts 500w ---> GONE to Fastvan67
Antec Earthwatts 500w ---> PENDING to Fastvan67
5 used black dvd burners
--- GONE ---
Are the DVD burners IDE, SATA, or a mix?
Potentially interested in one to finally fill this empty 5.25 bay missing a faceplate in my case after 8 years, but I know it's probably more trouble than it's worth to ship only one.
Thanks!
Anybody have some
DDR3 sticks any speed
LGA1366 CPU 5500/5600
Trying to build a rack mount server as the little dell Core 2 Quad really long in the tooth now
heck even a 1U or 2U server
Anybody have some
I have a few 1366 xeons and some ECC DDR3. How much do you need?
Haha, I remember when the Xoxide tray thing was new (over 15 years ago). Unfortunately, the PC tower is next to the TV, so about 9-10ft away. I got tired of re-taping it closed with electrical tape, so I now keep it open for airflow :).
Get the drawer then. Failing that go old school. Grab a wiremesh pencil holder, cut top and bottom off and flatten it then form to shape and hold in via glue
Thanks!
All SATA. 1 drive is 1 lb 8 oz., So cheapest would probably be usps flat rate bubble mailer. I can fit all 5 in a usps medium flat rate.
Have some items for the cost of shipping. Let me know what you want. Not totally sure on the working condition of these item as they were pulled from machines I have had laying around for some time. Figured someone might want to take a shot.
- 1 x Intel e2160
- 1 x Intel Pentium D 820
- 1 x Nvidia Geforce 8300GS 128MB Pci-E Card
- 2 x 512MB DDR2-533MHz
- 2 x 1GB DDR2-800MHz Kingston
- 2 x 1GB DDR2-667MHz
- 2 x 256MB DDR2-667MHz
- 1 x DVD Rewriter Model: GSA - H73N
- 1 x CD-RW/DVD-Rom Model: DH-48C2S
View attachment 290929View attachment 290930View attachment 290931
Still have all of this available if anyone is interested.
SATA spinners up for grabs as a lot: (Laptop drives; tested working, 5-pass wiped, single simple NTFS partition created)
1x slim 320GB 7.2K HGST / Lenovo FRU 42T1159
1x 160GB 7.2k HGST / Lenovo FRU 42T1461
2x 320GB 5.4k HGST (5K500 B-320)
1x 160GB 5.4k Toshiba MK1655GSX
SATA spinners up for grabs as a lot: (Desktop drives; tested working, 5-pass wiped, single simple NTFS partition created)
2x 500GB 7.2k WD Blue
1x 500GB 7.2k Toshiba
SODIMMS lot (as-is, were working when last pulled)
1x Kingston DDR2-6400S 1GB
1x CORSAIR 2GB DDR2 667 (PC2 5300) "Memory For Apple Notebook" [Model VSA2GSDS667D2]
2x ASint DDR3 2GB-1333 [SSZ3128M8-EDJ1D]
1x SKHynix DDR3 (Google suggests this is a 4GB DDR3L-1600 4x4) [h5tc4g63afr on the IC]
Gone/Pending to SamirD
If anyone has a SATA DOM that they're not using at least 16GB, I'd be interested in one.
Anyone have the screws from the FRONT of a 1080TI FE? Just the screws but I would pay postage for the whole thing (NOT trying to revive a dead card) if you are lazy like me and don't want to screw with it. Finally found one but I know the kind of noise level I am going to hear as soon as it arrives.
I have five Intel Xeon E5-2620 CPUs available. Pulled from recycled servers. All tested working. Includes a 3d-printed CPU carrier/holder as well.
Asking $5 shipped within the USA each. Otherwise you just pay $5 in packaging/materials plus actual shipping costs if you want the lot.
EDIT: Gone
Gone, to ThreeDee - I have these ddr3 sodimms that are not being used. I tried to give them away, before, but never heard back from the gentleman. If anyone wants them, they are yours for the shipping cost.
