The [H]ardForum Perpetual Freebies Thread
Furious_Styles YGPM.
If anyone has a spare pentium pro, you would be my hero. I uncovered a dual socket pentium pro board and the second socket was unoccupied. I believe socket 1 is 200mhz. Ooh the options! Thanks guys!
I think they have to be the same stepping to pair up, might wish to check first.
Oddly enough, look what I have on the bench yesterday.
Hello guys
Im looking for a reference NON-blower cooler for R9 290. As I know pcb is compatible with 290x, 390, 390x.
Thanks in advance
Does anyone have like a half dozen to dozen old laptop batteries laying around? I've been thinking I would like to try one of those DIY powerwall things but wanna fool around on the cheap first and see if I can make sense of it
So you just want donor cells and don't care if they actually charge until you get the design figured out? If so, I actually do have at least 4-5 for you. PM me if you want more details on them so we don't clutter up the thread too much.
I'm actually going right by the post office in a couple of hours, so I could get them out today if they're what you're looking for.
edit: Batteries are on the way to Davan. Good luck with your project!
And in a super long shot, I need a mobo for a gopro 3+ black edition.. ;) These are apparently the same cost of buying an entire used unit. :/
Still holding out for an AM3 motherboard; needs to have 4 memory slots.
I got an Asus M2N61-AR setup here
Its an ITX thing, got 2G ram on it, CPU and HSF. Its a runner, had a bad PSU, some proprietary small form factor. I cut the plug off the PSU and built an adapter to get a regular ATX supply on it to get this girl's data off. She said she was going to buy a new PSU but never did.
Free for shipping.
gone to 404
Sirius S12 receiver with antenna, needs a 5V power brick.
Escort Solo4 radar receiver gone to kakureru
EKWB EK-multioption RES X2 TOP W/thread
2@ Samsung 2GB M471B5773CHS-CF8 DDR3 sodimms
escort solo4 radar receiver
as in radar detector? interested.
yeah, as I recall the battery door is a little wonky on it, I think I was taping it shut.
please note this is NOT the more modern S4...just 4
Still available: Socket 775 matx motherboard + CPU.
The board is from an HP. tested board and cpu. It boots to bios and passes a simple hp diagnostic check.
Who ever pays for shipping first gets it.
This includes CPU, motherboard, heatsink and I/o shield. CPU is an E5300 pentium D.
Images of it working:
imgur.com/otTHWa4.jpg
imgur.com/RSbU16K.jpg
gone to 404
My Perc 5/i memory died...
Any chance anyone have
DDR2 PC2-3200R Registered-ECC 256MB 1Rx8 Single Rank-Single Bank
Actual Part# is
HYS72T32000DR-5-A
Would it support:
Samsung Model: M393T6450FZ3-CCC
Capacity: 512MB
Type: ECC
Slot type: DDR2
Speed: PC2-3200R/400MHZ
Pins: 240-Pin
Looking for H97 or Z97 ITX motherboard in working condition...!
Have working i7-4770S & 16GB of Corsair Dominator RAM; but on crappy ASUS OEM "mATX" motherboard, need ITX for smaller chassis...
Anybody need an older laptop? edit: claimed
Dell Latitude D505
Pentium M 1.50 GHz
512MB DDR (2 x 256MB)
40GB Hitachi HDD
Windows XP Professional SP3
*Does* need new battery, but works fine off of a charger (not included; I am using a higher wattage one from another laptop)
Probably needs new CMOS battery, as I've had to reset the time/date in BIOS each time I've turned it on.
Sorry for the poor lighting. Wifi works although it just disconnected and reconnected for some reason but I have a relatively noisy environment with multiple bands going. Has LAN port as a backup if the card ends up being problematic. Just pay shipping if ya want it.
Dell Latitude D505
Pentium M 1.50 GHz
40GB Hitachi HDD
great option for running special software/accessories that do best on XP. Sure someone will get it for that reason.
This might be asking too much. Anyone have a single low-capacity DDR4 stick (1GB even, can be 2666/ 2400/ 2133) for cheap or free? I can't find anything lower than 4GB sticks, maybe they don't make them lower?
Basically just need the cheapest of cheap (but working) DDR4. Have a friend that has a desktop computer that works fine once the BIOS is configured to run DDR4 3000, but if his CMOS ever clears/resets it wont boot again until he boots with 2666 or lower and then reconfigures XMP again and swaps back to the DDR4 3000 RAM. Unless anyone has a better solution. CMOS clear should be rare, but figured a spare stick for emergency boots might not be a bad idea.
if you dont mind asking, what board is that, Sounds like one I would like to avoid :/
I owe a couple people boxes, do not despair. Things are starting to return to normal, weather wise, and I made it out to pick up flat rate boxes. Stuff is tested and packed, try and get it out tomorrow.
The JEDEC spec for DDR4 specifies a minimum capacity of 4 GB per stick at any speed. There may be smaller modules that don't conform to the standard, but they're very uncommon.
Reactions: xx0xx
Ah, gotcha. Well, either way, a 4GB stick is like $20ish bucks for a cheap one, which is all he needs so I think we'll go for that. Figured I'd ask here before going that route. Thanks!
462/A Asus A7VBX-MXSE
462/A Duron 900 DHM0900AQS1B
462/A Athlon XP 1600+ AX1600DMT3C
462/A Athlon XP 1900+ AX1900DMT3C
462/A Athlon XP 2100+ AX2100DMT3C
462/A Athlon XP 2400+
462/A Athlon XP 2500+ AXDA2500DKV4D 2@
462/A Sempron 2600 SDA2600DUT3D
462/A Athlon XP-M 2600 AXMG2600FQQ4C
462/A Sempron 3000 SDA3000DUT4D
462/A Athlon XP 3200+ AXDA3200DKV4E
754 Sempron SDA3100AIP3AX 1.8GHz
754 Sempron SMS3300BQX2LF 2GHz 25W
S1 Turion 64 x2 TMDTL58HAX5DC 1.9GHz 35W
S1 Athlon AMGTF20HAX4DN 1.6GHz 15W
495 mPGA2 P3 SL3LG Coppermine mobile 0.45GHz
478 P4 SL5TJ 1.5GHz
478 Celeron SL6HY 2GHz
478C PM SL7SM 2GHz
M Celeron SL92F 1.733GHz
LGA775 P4 630 SL7Z9 3GHz
APC shark rack LCD-15-1
Free! Up for grabs:
Matching pair - Ramaxel 512mb 1RX8 PC-5300S-555
Tyan SLI Bridge
Brand New Still Sealed! The Elder Scrolls IV - Shivering Isles - Expansion Pack for Oblivion
Brand New Still Sealed! Space Siege
I have an Intel Compute Stick available for free, just pay shipping. Model BOXSTCK1A8LFC. Everything is included but I wiped the internal storage and don't have time to track down the right distro to reinstall.
This came preloaded with Ubuntu 14.04 and I blew the recovery partition away. Linux device support for the built-in wireless and NIC is a bit spotty, but newer versions of Ubuntu should work.
I'll take!
478 P4 SL5TJ 1.5GHz
478C PM SL7SM 2GHz
I'll take all the 462/A stuff. sending you a PM now.
I paid $35 for this on clearance back in 2017. My loss, your gain.
This is still available, FYI.
Kind of a long shot, but does anyone have extra GPU cables for the Enermax Modu82+ series?
