The [H]ardForum Perpetual Freebies Thread
Heads up fellas. FREE Lian Li case in Dallas (LBJ and Skillman)
I need another case like I need a hole in my head, so feel free :)
https://dallas.craigslist.org/dal/sop/6209485449.html
Someone must have gotten the case cause the CL post is now deleted. The case looks like a PC60USB model
Anyone have a am3 cpu sitting around? I've got a single core in it now but its just not cutting it anymore.
Also looking for a 1-1.5 gb IDE hdd. the one I had in my Dos gaming machine suddenly crapped itself and died.
I have an e350 amd set you're welcome to.
OK sorry :) I have only heard of the Ford motor company version of the E350 I did not know it was a term in the computer chip world also only a big ol' van or stripped chassis vehicle (That is used to make Ambulances, Buses, and Box trucks)
Does your board support core unlocking? Most of the single core AM3 Semprons are dual core parts with a soft locked core. I have a Sempron 130 which unlocks to an Athlon x2 4300e and has been perfectly stable for years. Some boards call the core unlock "advanced clock calibration".
Yeah, the AMD E350's Ford equivalent is the Pinto.
Have: amd OEM apu HSFs
Want: 120mm fan, preferably quiet-ish, molex or 3 pin ok
1/8" to dual RCA splitter
I looked into this, my board does. The cpu shows as an athlon x2 whatever but windows immediately crashes.
If you're running XP you may be able to fix that. Boot into safemode, run devmgmt.msc, then try switching from apm to acpi under Computer (or the other way around been awhile).
May also have to bump the voltage as well. Some unlocked cores needed a small bump in Vcore. hence why they ended up as Semprons.
Running Win10, not gonna mess with it. Will wait till the package from vaulter gets here.
I have one extra of the Nvidia For Honor/ Ghost recon promo codes, Free to the first person who activates it. OJWZ-SAJN-LYQR-NZGX-HBVR-HTQG.
would anyone have a 2.5" ide harddrive at least 100gb?
I may have one, I'll check my parts bin tonight. If so, you can have for the cost of shipping.
Also looking for a low profile video card for an old machine running a Core 2 Duo and 4gigs of ram. Anything that will boost performance from the onboard video will work.
I am looking for ND filter(s) for up coming eclipse. (Also looking for one of those phone eclipse kits with the zoom lens and filter) Not expecting free but cheaper = better ;)
Looking for a decent~ish 8" to 10" tablet, my mom is 79 and it would be nice to not have to go upstairs every time she looks something up.
Would only really be used for reading and/or web stuff, so 1GB to 2GB RAM would work, prefer Windows so she doesn't have to learn new OS
Appreciate you guys and thanks for any assistance you can give !!! <3 :-})
Does anyone have any Torx Screwdrivers that fit 3.5" HDDs? (I think T5, T6, T7)?
As a personal project I want to open an old dead IDE drive and take a look around. Not sure exactly which Torx this takes but it's an old Seagate.
Tried small flatheads but they started stripping the screws (and in one case, broke the tip of the flathead because it was a cheapo soft one)
Yeah, the reason I'm looking for free/cheap is I rarely need them otherwise and would rather not waste money on a set. This is the first time in my 31 year life that I've ever needed a Torx (and only for a personal project) and I doubt I'll run into a need for them again
Yeah after some searching just found a super cheapo set on ebay for like $3 so that works. Thanks for the suggestions.
Does anyone have those DVI to VGA adapters they turned into headless dummy plugs using 3 (I think) resistors? I had like a dozen of them, asked around, no one wanted em so I tossed em, now just a few months later I need to try a theory but I don't have any left lol, go figure
Need a bunch, I've got 3 adapters left here I'm going to convert but I still need to look into what resitors and if I can buy those from China
HDMI headless ones may work too but those are looking about 10 bucks each on ebay, hoping to be cheaper than that
EDIT - Not needed anymore, found a better option via Linux
Anyone happen to have a genuine leftover Acer C720 Chromebook AC Adapter/Charger?
Found out mine is after-market and not properly grounding, rendering the touchpad useless while plugged in due to a ground loop, and potentially making the device dangerous to use in general
A very noisy power supply will also cause that issue. But yea, stop using it ;)
Reactions: xx0xx
Anyone have 125 student laptop code for best buy? Need to get my wife a work laptop!
I moved a while ago and (don't ask me how) I succeeded to loose the modular cables for my trusty Cooler Master Silent Pro M850. If anybody having laying around some spares (or even a ful set from a dead PSU) I will gladly appreciate here and also on PayPal :))
PS need SATA and PCIe cables, eventual molex ones (to be there)
