The Great Keyboard N-Key Rollover (NKRO) Test/Round-up
Curunen
Eprex 5139H mini keyboard.
Both Shift Keys + Caps Lock:
th quick rwn fx jumps riht vr th azy
Ripster55
A fun and easy test for your keyboard's N-Key rollover ability is to hold down both shift keys and try to type in the following:
the quick brown fox jumps right over the lazy dog
This "Right" thing just ain't Right. Shows the amount of thought that went into posting this test.
kniah
Sorry to revive this thread but just got a new keyboard in: Das Model S Professional Silent
Both shift keys + caps using PS2 adapter:
Looks like the NKRO works as advertised :)
Ripster55
Right or not it still gets the point across.
THE QUICK BROWN FOX JUMPS LEFT OVER THE LAZY DOG
Filco Gen2 Tenkeyless Cherry Red Limited Edition
I CHEATED!!!!! I USED THIS KEY BECAUSE THIS IS THE STUPIDEST TEST EVAH BECAUSE SOME 2KRO KEYBOARDS PASS IT!
Highwind
without capslock, then with:
TE UIC RWN JUS RIGT VER TE LAY DG
Logitech Pro 2000
cheese007
TE QUICK BROWN FOX JUMPS RIT OVER TE LAZY DO - Saitek Eclipse III
thequickrowfoxjumpsrightoverthelzydog - Toshiba L655
nothing- Dell SK-8115
HE QUIK BRON FO JUP RIGH OER HE LA DOG - Logitech Cordless Desktop EX110
te uic rwn jups rigt ver te lay dg- Gateway 2000 E06150US011-C
nothing- Saitek Eclipse II
Like the massive improvement from the Eclipse II to III.
avddreamr
the quick brown fox jumps over the lazy dog - razer tarantula... well at least it's good for something.
Unknown-One
Saitek Eclipse II (Left shift + right shift):
HE QUIK BROWN FO JUPS RIGH OER HE LA DOG
Saitek Eclipse II (Left shift + right shift + caps lock):
<utter failure, nothing typed at all>
Ripster55
Don't get cocky. It's just a coincidence - the way the matrix was laid out.
Now the Sidewinder X4 - that WAS a technological achievement. 26KRO over USB.
More than enough for fingers AND toes.
Mackowitz
Both Shift Key:
Both Shift Key + Caps Lock:
he quik brown fo jups righ oer he la dog
HP Model KB-0316
schizrade
H CK BN FX JMD V H LAZ DG
2007 era Apple aluminum :rolleyes:
Dell AT101W - Perfect ($2.99 at thrift store)
IBM 1996 Trackpoint II - Perfect ($2.99 at thrift store)
IBM 1993 Model M - Perfect (given to me)
FLECOM
Modder(ator) & [H]ardest Folder Evar
Staff member
two shifts + caps lock on model m = no output
two shifts
HEQUIKBROWNFOJUPEDOERHELADOG
apple aluminum two shifts + caps lock
hckbnfxjmdvhlazdg
two shifts
HCKBNFXJMDVHLAZDG
Ripster55
Two IBM Model M results posted in a row by two different people.
One passes, one doesn't.
I think there is significant measurement error in this test.
Spare-Flair
Razor Blackwidow Ultimate Mechanical Keyboard. Not NKRO because it's USB.
Two Shifts:
THEQCKBRWFXJVERTHELAZYG
Two Shifts + Caps Lock:
EGOvoruhk
XArmor U9BL-S plugged in via USB
Both shifts and caps lock: the quick brown fox jumps right over the lazy dog
Ripster55
Lulz.
Lots of 2KRO laptops can type that phrase correctly. It all has to do with how the engineer decided to route the Rshift and Lshift traces and NOTHING with PS/2 versus USB. Although USB is better.
But carry on.
schizrade
two shifts
hckbnfxjmdvhlazdg
two shifts
HCKBNFXJMDVHLAZDG
Then it is some strange iteration of the Model M/defective/not a model M. All mine perform flawless with both shifts and caps.
Dell AT101W does as well.
Edit: I see from the Model M thread you are using a PS2>USB adapter. That explains that.
shoota
THE QUICK BROWN FOX JUMPS RIGHT OVER THE LAZY DOG
2009 Macbook Pro
owned hehe
plugwash
the sad thing is that with modern microcontrollers it really wouldn't be that hard to build a keyboard with 105 key rollover.
Ripster55
2009 Macbook Pro
owned hehe
Yep. That's one that's 2KRO and passes the test.
Try hold down A, S and then pressing X and see if X registers.
If STD tests were administered this way there would be a lot more people on penicillin.
Ripster55
The G15v1 passes, the G15v2 doesn't.
Both keyboards are 2KRO.
In fact ALL these keyboards give FALSE POSITIVES. They pass the test but will fail other 3 key combinations.
Macbook Pro 13 ", 15" (i5 version)
Cherry ML4100
Dell AT101W
Dell SK-8110
Logitech G11
Logitech G15V1
Logitech G19
Logitech K340 Wireless
Microsoft Digital Media Pro
PC Concepts SK-6000
Razer Tarantula
But please carry on.
OFaceSIG
Alienware TactX (I'm glad I didn't pay for this damn thing).
THEQCKBRWFXJVERTHELAZYBRWG
theqckbrwfxjverthelazybrwg
jjorloff1
HE QUIC BROWN OX UMP RIGH OVER HE Z OG
Rosewill RIKB-11001 X-Slim Chocolate Style Keyboard
sirmonkey1985
[H]ard|DCer of the Month - July 2010
Razer Lycosa with falsely advertised 3 key bypass.
HE QUIC BROWN OX UMPS RIGH OVER HE AZ DOG
and for the "idiot" that wanted right removed from it..
HE QUIC BROWN OX UMPS OVER HE AZ DOG
(it doesn't make a difference if the word "right" is there or not there)
i can't do it while holding the ctrl key down because i know for a fact the 3 key bypass does not work on this keyboard..
StatutoryApe
ABCDEFGHIJKLMNOPQRSTUVWXYZ - Both Shift
ABCDEFGHIJKLMNOPQRSTUVWXYZ - Both Shift and Caps
6 key combos
wesdqa
xsdcaz
fxsdcv
werfsd
gfhsda
alskdj
xcmbzn
cant do qwe and iop. doesn't print anything.
iopxcz
weqmbn
7-key combos dont seem to work, but i never press 3 keys at once, let alone 7.
This is on a G15v1. They must have done something right.
