The best gaming mouse EVER is back
Discussion in 'Mice and Keyboards' started by PeaKr, Feb 20, 2019.
  1. gamz247
    gamz247 Gawd
    643
    Jun 9, 2003
    I received my MX518 last week, and tried it out over the weekend. Compared to the G400 that I had been using, the left and right buttons were much louder, and the scroll wheel "ticks" as it spun were much less distinct. Clicking down on the scroll wheel felt "mushy" as well. These issues were enough for me to return it. YMMV.
    legcramp likes this.
  2. Deserving
    Deserving n00b
    24
    Apr 7, 2015
    Hah I was hoping to a the MX518 when opening this thread. I used mine until it started double clicking. Too bad it isn't the cool grey and black pressed looking pattern.
  3. Spoom
    Spoom n00b
    53
    Mar 1, 2016
    I had the red mx510!
    Armenius likes this.
  4. XoR_
    XoR_ Gawd
    654
    Jan 18, 2016
    I think Logitech G502 is the best
    Once you get used to cool metal scroll wheel there is just no going back :cool:
  5. MacLeod
    MacLeod [H]ardness Supreme
    7,563
    Jul 28, 2009
    I bought one a few weeks ago and absolutely love it!
    The DeathAdder is the perfect mouse for me ergonomically and was my current favorite for about a decade but the Logitech G502 is the sensor I wanted. Once you use that sensor it's hard to go back.
    The G MX518 is now my new favorite. While it's shape isn't as perfect ergonomically as the DA, it's awfully damn close. But best of all, that wonderful sensor is surgical!! It's gotta be the best on the market, it's easily the best of the gaming live I own and I own about a dozen.
  6. Nenu
    Nenu [H]ardened
    18,587
    Apr 28, 2007
    Naa it aint (The best gaming mouse EVER), the Logitech G502 Hero is mad good.
    As long as it remains reliable this is what I will recommend.
    I still have an MX518 but it didnt get much use for a long time and when it eventually did it developed a cable fault (I think).
    It sort of works if you are ok with waiting a moment every so often.
  7. Armenius
    Armenius I Drive Myself to the [H]ospital
    16,538
    Jan 28, 2014
    The shape of the 518 is nothing like the 502. The latter was clearly made for claw grip, and it is overall a lot smaller. I'm not a big fan of the 502, but I absolutely love the 518
  8. maro
    maro Limp Gawd
    489
    Aug 27, 2006
    There are differences due to styling, but the 518 and 502 ARE similar in size and shape. Perhaps you are thinking of the G Pro which is exactly all of those things you mentioned (smaller overall and suitable for claw grip).
    I own the og MX518 and the early G502 (non Hero version) and I stand by what I wrote. They are similar - but don't take my word for it - you can see the size specs from Logitech website on both. They are for the newer versions (G502 Hero and MX518 Legendary) and the differences between the two are in millimeters.
    Manny Calavera likes this.
  9. MacLeod
    7,563
    Jul 28, 2009
    I also own both the 502 and the 518 (I have a mouse fetish and buy a new mouse a few times a year) and when you hold them up next to each other they do appear to be about the same size but the 518 is a little taller and a little fatter. It ain't by much but it's just enough to fill up my hand better and it's just a lot easier to move around than the 502. Don't get me wrong, the 502 is a superb mouse, easily one of the best on the market but for my hand, the MX518 is a little better. I also own the G400 and while it's basically the same shape of the 518, the sensor isn't as good and that makes a huge difference.
  10. maro
    maro Limp Gawd
    489
    Aug 27, 2006
    My main gripe against the 502 is the Batman styling. The thumb rest took a little getting used to but I grew to like that. I do agree that in spite of their similarities they do have different feel to them - and I do prefer the feel of the 518, but they are similar enough that I felt if 502 causes wrist pain the 518 probably would as well.
    If I put my 502 guts inside my G400 shell I would consider it the perfect mouse! Until then I will eventually try the new 518 and its Hero sensor one of these days.
    MacLeod likes this.
  11. Manny Calavera
    Manny Calavera 2[H]4U
    3,607
    Jun 10, 2004
    Want to buy the newer MX518 Legendary , is it the same size as the OG MX518??
    Thanks.
  12. EJR357
    EJR357 n00b
    42
    Aug 27, 2012
  13. maro
    maro Limp Gawd
    489
    Aug 27, 2006
    I do not have the new one in my hands to compare to my OG (yet). It does sound like it is same or very close to the original, other than its weight. The thread EJR linked has some good hands-on discussion about it.
  14. kniwor
    kniwor [H]Lite
    109
    Apr 9, 2007
    Wa.. I had this mouse and it was with me forever. I remember it. I use a 703 now, but that's because I absolutely need something wireless (which can be wired when needed :) )
  15. LightsOut41
    LightsOut41 Limp Gawd
    428
    Mar 5, 2017
    I picked up a couple of NOS MX518s off Ebay for $30 each last week. I wish I would have bought these first before buying the new version for $60. The new version is far too light.
  16. Furious_Styles
    Furious_Styles [H]ard|Gawd
    1,142
    Jan 16, 2013
    I kinda wish I bought one of those back in the day. I used the classic microsoft optical blue mouse for a long time then switched to deathadders. The deathadders just sucked on durability. Typically get 1-2 years of use before something breaks.
  17. Hulk
    Hulk [H]ardness Supreme
    5,864
    Nov 4, 2005
    Best mouse of all time:
    Microsoft SideWinder Gaming Mouse (the original one).
    Been using mine for over 15 years now. You can't buy them anymore, that's why no one is going to tell you what their favorite mouse is (unless they stock up and buy 3 of them, wish I did that). You can still buy it though.....for $400 on Amazon.
    kniwor likes this.
  18. kniwor
    kniwor [H]Lite
    109
    Apr 9, 2007
    Just looked this up. The sidewinder seems to have small but ardent following!
  19. Dan_D
    Dan_D [H]ardOCP Motherboard Editor
    53,125
    Feb 9, 2002
    I saw one in a store and I didn't like the feel of it.
