maxinflixion
- Apr 2, 2007
I have an odd one that is causing some head scratching over here tonight,
I picked up a SATA DVD/RW drive today for my Linux PC as I have two IDE hard drives installed on the one IDE plug.
Simple install right? I plugged her in, and now my IDE drives are no longer recognized in BIOS, which means I don't boot.
Ok, it's something with the SATA drive I suspect, so I remove it from the equation.
Still, no IDE drives in BIOS or otherwise.?.?.?
I disabled SATA in BIOS just for kicks. Nothing.
Removed CMOS battery for a while and loaded Optimized Defaults in BIOS.
Plugged her back in and booted from CD. Worked, but no IDE drives visible.
Anyone have ideas?? My big fix will be to go grab a SATA hard drive tomorrow and re-install OS.
Specs:
ECS GeForce 6100PM-M2 (it's my budget Linux box...)
Athlon 64x2 4000+
2x40gb Mactor IDE Drives
LG Super Multi DVD Drive
7600gs GPU
Antec Earthwatts 500w
Specs:
Athlon 64x2 4000+
7600gs GPU
