The 2015 Post Pics Of Your Rig Thread!
qbanb8582
some current rigs...as always..."subject to change"
rig #1
rig #2
photos coming
What monitor is that?
Killahurtz
it's the Samsung UN48JS9000...4K "TV"...love it...I was looking at the JU7500 40" but it was not available in-store , this was at Fry's
qbanb8582
Ok it looks real nice. If you don't mind me asking how well does it do at 1080p? My question is can you set the resolution to 1080p it doesn't look the image being scaled? I'm considering getting a 4K over a 1440p or 1600p display but I want to know if for example can I set it 1080p, and look like a regular 1080p monitor. For some games I can run at 1080p until I get a better GPU to handle it at 4K.
Thanks
Killahurtz
not sure...when I attempt to choose "1080" it drops the refresh rate to "30hz"...I will try some settings and update the post
Schtask
A build I completed over Christmas.
ASUS X99 WS E
INTEL 5930K w/Raystorm Block
NVIDIA EVGA Superclocked GTX 980 X2 SLI w/ XSPC Razor Water Blocks
16gb Corsair DDR4 Dominator Ram
A vast amount of Primochill UV Blue Rigid Tubing and Revolver Fittings
Seasonic 1200w Platinum PSU
Samsung 840 EVO 500gb SSD, 250gb SSD and 1TB Storage
Phantek Enthoo Primo Case (My new favorite)
The slight crushing of this tube has since been corrected.
skypine27
Just snapped a couple of quick ones with my iPhone:
Theres a total of 10 x case fans in there! 8 x 140mms and 2 x 120 mms (the 2 x white ones on the bottom intake). But they all are fixed at approx 400 RPM so the case is actually near silent (except when the Titan X fans spool up under gaming)! Trust me when I say that 10 x fans at 400 RPM does NOT equal the perceived noise of 1 x fan at 4000 RPM. Its pretty freaking quiet :)
RGB lighting strips and a custom made mirror to cover the empty area of the case behind the intake fans next...
mnpctech
Case: Fractal Design Define S
CPU: Core i7, 4790, 3.6Ghz
Mobo: ASUS ROG Maximus VII HERO ATX Motherboard
SSD: Intel 520 SSD, 120GB
RAM: 16GB Corsair Dominator
GFX: 2x ASUS STRIX 970 GTX Video Cards
PSU: Fractal Design Tesla Power Supply 800W
Cooling:
EK MX CPU Waterblock
2x Hardware labs 360 GTS radiator
Laing water pump with Alphacool top
XSPC 240 Photon Res
EK 970 GTX Strix Waterblocks
EK 970 GTX Strix Waterblock Backing Plates
Monsoon Blue Economy Hardline Fittings
EK extender fitting
EK 90 degree fitting
PETG hard tubing
mangapc
Cooling:
XSPC 240 Photon Res
EK extender fitting
PETG hard tubing
This is clean. Sweet paint job on the case.
DraginDime
Just upgraded the guts of my rig from a P67-Deluxe/2600k/16GB DDR3 to X99-Godlike/5930k/32GB DDR4. Also swapped out my HX850 to a HX1200. Here's a quick pic for now, I'll have to take some better ones later to post.
I'm only running 2x 980Ti cards, the other two in the pic below are my old 780s. I wanted to see how it looked stuffed full of GPUs :D
D
Deleted member 126051
Guest
Just reorganized my computing area this evening once my Monoprice DVI-to-DP cables came in.
Need a better camera. My phone camera sucks.
Zenphic
I'm planning on upgrading to Skylake during Chritmas! Until then, this system is doing just fine.
AMD Phenom 9550 2.2 Ghz (K10Stat undervolting: 2.2 Ghz @ 1.0750V, 1.1 Ghz @ 0.8375V)
Gigabyte GA-MA78GM-S2H (rev 1.1)
Corsair XMS2 TWIN2X4096-6400C5 PC2-6400 2x2GB
Crucial DDR2 667MHz PC2-5300 CL5 2x2GB
Crucial M500 240GB SSD
Western Digital Green 3TB
Western Digital SE16 640GB WD6400AAKS
Noctua NH-U12P with Noctua NF-P12 @ 500 RPM with SpeedFan
Anidees AI6BS with stock fans + Noctua NF-P12 @ 600 RPM with SpeedFan
LG GH22NS30 DVD Writer
EVGA SuperNOVA 650 GS PSU 220-GS-0650-V1 PSU
XFX Radeon 5770 with Arctic Cooling Accelero L2 Pro @ 800RPM idle and @ 1300 RPM load (fan profile configured with MSI AfterBurner 3)
AMD Catalyst 15.7
Windows 8.1 Pro (x64)
Motley
Finally got me a new case. The Corsair 760T. Yellow and black theme.
I'm using the top cover from my old case (Switch 810).
Added filters on the front and rear intakes, and the top cover as well. So far the dust seems fairly minimal now.
I got the cable kit by cablemod.
List of components:
Case: Corsair 760T
Motherboard: MSI XPower AC
Processor: 5820K @ 4.4GHz 1.30v
16GB DDR4 2800 GSkill Ripjaws
Video card: MSI 390X
Cooling: Corsair AF140 fans, NZXT Kraken x41
Crucial 2x MX100 256GB SSD, 1TB Toshiba
Samsung S32D850T
PSU: EVGA G2 850
Mouse / Keyboard: Steelseries
Windows 10
Quartz-1
Two Titan X GPUs and a Nofan CR-95 in a FT05
Outside view:
Inside view:
Close-up of cabling at bottom:
Those are a couple of adhesive clamps from B&Q keeping the cables sort-of-tidy.
The horror story at the back:
I could not keep the 3.5" drive bay and decided to remove the optical bay as well.
walwalka
Outside view:
Inside view:
How well does the nofan work?
Quartz-1
Within its limits, brilliantly. I really cannot recommend it highly enough. You're not going to be overclocking with it, though. I do wish it were a little smaller in radius, but taller.
T_A
This thread needs some Skylake attention
nothing too fancy.
i7 6700K, Gigabyte Z170X Gaming 7, G. Skill 2X8GB DDR4 3000Mhz
Gigabyte Windforce 980 GTX OC, H100i GTX
Seasonic X 850W
Samsung 840 250GB Evo, 1TB Seagate
Corsair Obsidian 450D
mostly my 'gaming' is DCS flight sim, would you believe?...
exilelrrp
List of components:
Case: Corsair 760T
Samsung S32D850T
PSU: EVGA G2 850
Windows 10
You need to get those Thermaltake Riing RGB fans and make those blue LED into Yellow, match your color scheme. They have those SP120mm and SP140mm.
Nobu
The Riing fans are pretty nice. Static pressure is sort-of meh, but that doesn't really matter for unrestricted ports.
w1retap
Lian-Li v359B
Intel Xeon x5670 @ 4GHz
Asus Rampage III GENE (BIOS v1003)
24GB Corsair Dominator GT DDR3-2000
EVGA GTX 980 ACX 2.0
Samsung 250GB Evo 840
Seasonic Snowsilent 1050w PSU
Phobya DC12-400 Pump
Alphacool Lighttower Reservoir
EK Supreme CPU Block
2x 240mm Magicool Extreme Radiators
Nobu
Alright...now I need to buy a reciprocating saw, chop off the top of my case, and get some custom tempered glass made. o_O
