The 2013 Post Pics Of Your Rig Thread!
Discussion in 'Case Mod Gallery' started by HardOCP News, Mar 8, 2013.
  1. Cschill1290
    Cschill1290 [H]ard|Gawd
    1,617
    Nov 8, 2007
    Loving this new case. First Corsair case I've ever had and I see many more in the future. Corsair Obsidian 350D for those that are interested. Probably going to put a black sleeved 24 pin extension I have laying around in there next day off. Not liking the splash of color in there. Also need some black SATA cables instead of the UV blue ones.
    [​IMG]
    [​IMG]
    Edit: Added a sleeved 24 pin extension and the black SATA cables I wanted, along with an 8" white cathode and some white bladed fans. Here's how it sits now.
    [​IMG]
  2. emir_
    emir_ n00bie
    9
    May 12, 2007
    Some cleaning.
    [​IMG]
    [​IMG]
    [​IMG]
  3. Bluesun311
    Bluesun311 2[H]4U
    2,527
    Sep 21, 2013
    Testing New Camera-Canon 6D:
    [​IMG]
    Looking for suggestions on the easiest&cleanest way to get rid of the rats nest of Molex connectors I have assembled to make all the lighting strips work... I'm not in love with soldering but I can.
  4. Bluesun311
    Bluesun311 2[H]4U
    2,527
    Sep 21, 2013
    Nvm I just pushed them all behind the "cable management" area somehow...
    [​IMG]
    [​IMG]
    [​IMG]
  5. jamsomito
    jamsomito 2[H]4U
    3,228
    Aug 29, 2010
    Nice rig. Is that side fan blowing outward? You might get better temps on your GPU's if you have it pulling in.
  6. Bluesun311
    Bluesun311 2[H]4U
    2,527
    Sep 21, 2013
    Thanks! :)
    I used to have it the other way, but when I changed from a tower cooler to the little Corsair H55, I found I didn't have enough exhausts anymore and the cards actually prefer this config. I like using the 2 front 120mm's and the 2 140mm's on the top for intake, and this way I don't have to put an ugly filter in front of the fan in the window panel.
  7. jaffy
    jaffy [H] Custodian
    5,621
    Jan 13, 2004
    Just put this together:
    Corsair 540 Air & H100 + everything seen in sig.
    [​IMG]
  8. Midnite8
    Midnite8 Limp Gawd
    230
    Jul 29, 2009
  9. Acidsuicide
    Acidsuicide n00bie
    14
    Jul 4, 2013
  10. gar818
    gar818 [H]ard|Gawd
    1,336
    Sep 4, 2006
    Parvum S2.0
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  11. Blazeiam
    Blazeiam n00bie
    2
    Feb 23, 2010
    My first water build!
    [​IMG]
  12. JLangevin
    JLangevin [H]ard|Gawd
    1,181
    Apr 13, 2007
    Just a teaser until its done in the next week or two. This is not my PC, this is a build I am doing for a customer. Still have to plumb up all the PETG Tubing and wiring. All of the fans are currently wired, using power distribution blocks, its coming a long nicely.
    Project Red Mist:
    Intel 4770K with EK Supremacy Block
    ASUS Maximus VI Formula with EK Full Cover Blocks
    32GB Corsair Dominator Platinum 2133
    EVGA GTX 780Ti SC SLI with EK FC Waterblocks
    Corsair 1200i PSU
    AlphaCool 560 Radiator (GPU Loop)
    AlphaCool 480 Radiator (CPU loop)
    PrimoChill Revolver Rigid Tube Fittings
    CaseLabs SMA8 Case
    EK 250 X3 Reservoirs
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  13. JayJapanB
    JayJapanB [H]ard|Gawd
    1,449
    Feb 27, 2012
    Norprening it up.
    [​IMG]
    Backside
    [​IMG]
    Nice glass res.
    [​IMG]
    Annnnd... no window.
    [​IMG]
  14. JoeOnePack
    JoeOnePack Limp Gawd
    179
    May 18, 2012
    Sweet looking rig man. Love the black theme.
  15. D4rkn3ss
    D4rkn3ss 2[H]4U
    2,590
    Jun 30, 2010
    @JayJapanB - norprene, noctua, all black, aluminium, no window. i like your style man :cool:
  16. JayJapanB
    1,449
    Feb 27, 2012
    Thanks, guys! I like investing in the little things.
    Also I happen to like some things that aren't so popular. Bare aluminium interiors, Noctua colours.
    Spot the difference :p
    This was it before:
    [​IMG]
    After:
    [​IMG]
  17. aerial-
    aerial- Limp Gawd
    190
    Mar 13, 2011
  18. AceGoober
    AceGoober Live! Laug[H]! Overclock!
    22,406
    Jun 25, 2003
    Removed pic to place in 2014 thread.
  19. Karlitos
    Karlitos n00bie
    53
    Jul 17, 2011
  20. EnvymeRT
    EnvymeRT Limp Gawd
    208
    Mar 18, 2013
    Wow ....... after looking at this thread it makes me want to customize my PC. Some of these are absolutely incredible.
  21. mnpctech
    mnpctech Limp Gawd
    484
    Aug 17, 2002
    The hardware is combination of old and new, since progress has been staggered over past 3 years. The chassis is a Cooler Master 912 turned 90 degrees, and it's been 3 years since the ASUS P67 Sabertooth TUF shield was airbrushed with the Giger theme. The system has two separate liquid loops, the stainless tube reservoir is for the Radeon Crossfire GPU loop (2x 270x) with Hardware Labs Black Ice 360 GTX. This radiator is cooled with Panaflo L1A (38mm thick, 68.9 CFM. Max. noise: 30.0 dB-A). The 360 radiator grill is from Mnpctech.com with D5 pump and Alphacool top, the CPU is 3570, 3.4 GHz, with Swiftech's new Apogee XL waterblock. This is a great waterblock for $69.99. It comes with interchangeable illuminated face plate, which my good friend EEL Ambiense designed a replacement with a Giger-esque design. The cpu loop is PETG hardline tubing with EK 190 & DDC res / pump combo with Hardware Labs Black Ice 120 GTX radiator. Both loops are running distilled water. The system utilizes 32GB of their ADATA's new XPG V2 DDR3, and their Premirer Pro SP920 256GB SSD. The power supply is Corsair 750W. I'll be using this PC in the shop for video editing primarily.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  22. MouseTrap
    MouseTrap Limp Gawd
    262
    Jun 16, 2012
    ^Very Nice Work!!!^ Glad you finished it, now put it to work...lol
  23. Dave1231
    Dave1231 n00bie
    1
    Jul 28, 2014
    [​IMG]
    [​IMG]
    Corsair Carbide 500r Case
    EVGA SuperNova 850
    AMD FX 8350 @ Stock Clocks for now
    Corsair Hydro Series H80i
    G Skill Ares 16GB 1866 RAM
    Gigabyte GA-9701A-D3P
    Adata Xpg SX900 256GB SSD
    Crucial 3.5 120gb SSD for Game Storage
    500gb HDD for Storage
    3 Bitfenix Alchemy SATA cables connecting these (Can't see unfortunately)
    XFX R9 270x in XFireX
  24. CBlakeNS
    CBlakeNS Gawd
    808
    Dec 29, 2002
  25. Concentric
    Concentric Gawd
    1,005
    Oct 15, 2007
    Holy shit, this looks awesome. Very nice work.
  26. Carouselambra
    Carouselambra Gawd
    558
    Mar 7, 2014
    Did you make that Quake logo?
  27. daro2096
    daro2096 Limp Gawd
    133
    Sep 12, 2010
  28. Neutrino
    Neutrino Gawd
    570
    Nov 10, 2005
  29. Mannymal
    Mannymal Limp Gawd
    215
    Oct 12, 2011
    Man, watercooled rigs sure have come a long way since 2004...
  30. mangapc
    mangapc Limp Gawd
    290
    May 20, 2010
    Yeah I would agree.
