There is a voltage regulator heatsink slot on a Tforce 6100 AM2. With holes for holding pins. This is below the ports and above the heatsink where most of the caps and resistors and such are pritty much the 3 phase voltage supply.
I want to know where I can buy a heatsink that would fit this with holding pins. Or some good chip heatsinks. I don't like the taped ones. So cheap they fall off the bloody chip. >_> I'd really like to know if I can get some nice copper heatsinks for that part of the mobo.
Something like what ASUA use on their high end boards even.
Anybody know?
Thanks!
Anybody know?
Thanks!
