- Apr 10, 2003
Tesla has announced that new Model S and X vehicles officially have Steam OS integration. This means that Tesla owners can play thousands of games like Cyberpunk 2077 with fully wireless controller capabilities.
Can only open the Arcade when in Park.yeah, cause their distracted "driver" problem wasn't bad enough...
Only a matter of time till someone finds a way to bypass it.Can only open the Arcade when in Park.
Or push the button on the steering wheel and say what you want to do. And it works very well. (I actually own a model S and have experience here)Only a matter of time till someone finds a way to bypass it.
Teslas are already bad enough having the HUD in the center of the car, way outside the driver's view of the road, forcing them to look down and away from the road when they want to do some action. I'll keep my analog buttons and rotary dials.
https://www.tomshardware.com/news/amd-ryzen-tesla-model-3-model-yDoes that mean Tesla's have an x86 CPU?
Quad Core 3.8Ghz Zen+ With RDNA 2
Probably somewhere between a Deck and a PS5 performance wise ? Perhaps.
EDIT:
https://videocardz.com/newz/tesla-c...n-ryzen-embedded-apu-and-discrete-navi-23-gpu
Actually not a APU apparently it has a custom GPU... something like a Radeon Pro W6600.
Might be pretty good performance with SteamOS.
Next-Generation Gaming Consoles | |||||
VideoCardz | Tesla Car Computer | Sony PlayStation 5 | Xbox Series X | Xbox Series S | KFConsole |
Picture | ![]() | ![]() | ![]() | ![]() | ![]() |
CPU | 12nm AMD Zen+ (Ryzen Embedded V180F) | 7nm AMD Zen2 | 7nm AMD Zen2 | 7nm AMD Zen2 | 14nm Intel Core i9-9980HK |
CPU Config | 4C/8T | 8C/16T | 8C/16T | 8C/16T | 8C/16T |
CPU Clock | up to 3.8 GHz | up to 3.5 GHz | up to 3.8GHz | up to 3.6GHz | up to 5.0 GHz |
GPU | AMD RDNA2 (Navi 23) | AMD RDNA2 | AMD RDNA2 | AMD RDNA2 | NVIDIA TURING (TU106) |
GPU Config | 28 CUs | 36 CUs | 52 CUs | 20 CUs | 30 SMs |
GPU Clock | ~2.79 GHz | 2.23 GHz | 1.83 GHz | 1.57 GHz | 1.68 GHz |
GPU Power | ~10 TFLOPS | 10.28 TFLOPS | 12.15 TFLOPS | 4 TFLOPS | 6.5 TFLOPS |
Performance Target | up to 200mph | 4K up to 120fps | 4K up to 120fps | 1440p up to 120fps | 4K with RT |
MSRP | $122,990 | $399*-$499 | $499 | $299 | TBC |
Release Date | June 2021 | November 2020 | November 2020 | November 2020 | TBC |
Notes | Comes with a car | * Digital Edition | Comes with a Chicken Chamber |
My thought, exactly, since it takes 30-40 minutes to fully charge on a Supercharger. Could just bring your Steam Deck with you, though.Gives you something to do while your sitting at a charger I guess.![]()
How about we just get rid of the screens and go back to ergonomic controls?there was screen tech that made physical bumps/buttons on the screen depending on screen context, and then went back to being flat when screen context changed, haven't heard anything about it in years, bummer. it would be nice to have that for tesla screens to make tactile buttons when in driving mode for like ac and stuff, and then screen could be flat for media
https://www.wired.com/2009/05/prototype-display-combines-touchscreen-morphing-buttons/
You act like twisting a windshield wiper stick is simpler than taking your eyes off the road, a quick tap of the screen -> Home button -> Settings -> Controls -> Visibility Settings -> Front -> Rain Management -> Level -> 2 -> OK -> Back -> Back -> Exit -> Apply Changes -> Yes -> Reboot -> OKHow about we just get rid of the screens and go back to ergonomic controls?
haha incredibleYou act like twisting a windshield wiper stick is so much simpler than taking your eyes off the road, a quick tap of the screen -> Home button -> Settings -> Controls -> Visibility Settings -> Front -> Rain Management -> Level -> 2 -> OK -> Back -> Back -> Exit -> Apply Changes -> Yes -> Reboot -> OK
But I guess not everyone can afford a Tesla.
I had a new BMW 750iL loaner. The gimmick the infotainment unit had was hand gestures. If you wanted to turn up the volume, you had to twirly whirly your fingers clockwise and anti-clockwise. Changing the station was some sort of frantic hand waving. If you didn't look like a big enough knob for driving one in the first place, imagine being at a stoplight doing some twirly whirlies trying to turn down your NPR.
If it wasn't wouldn't that be an HDD, Heads Down Display?The Heads Up Display (HUD) is right in front of the drivers face on the windshield, no need to look down and away from anything to see and use the information available on the HUD.
Or use the buttons on the steering wheel, or the knob and buttons on the dashboard, you don't have to use gesture control, they have at least 4 other ways to do all of those things through the steering wheel, iDrive controller, physical buttons on the dash or voice control.
It's only on the Model S and X right now. Model 3 renters are SOL.An additional $400+ to play on a 7" screen or play for no additional cost on a 17" screen? I'm good with the latter.
No shit. I get real tired of cars wanting to have everything buried on a touch screen. It is fine for deeper information/controls. Like my car will let me change how it operates the door locks, do they lock when you start moving, do they unlock in park that kind of shit. That is fine for a touch screen. It is a feature you have no reason to change on the road. But for thigns like climate control, answering the phone, the radio, nav, etc these should all be easily accessible, well designed buttons or knobs.Touchscreens are amazing for displaying information and for simple one or two answer button presses. They suck at literally everything else. Thank Christ for steering wheel control integration......
Agreed. The other problem with touchscreens is that often some information is covered with other information. For example, in the Ram I just rented, in order to change the vents being used, I had to tap the climate button, exiting out of Android Auto, change the vents, then switch back to Android Auto for navigation. Way too many presses for what should have been taken care of by a single button.No shit. I get real tired of cars wanting to have everything buried on a touch screen. It is fine for deeper information/controls. Like my car will let me change how it operates the door locks, do they lock when you start moving, do they unlock in park that kind of shit. That is fine for a touch screen. It is a feature you have no reason to change on the road. But for thigns like climate control, answering the phone, the radio, nav, etc these should all be easily accessible, well designed buttons or knobs.
Yes, I have an external SSD hooked up through the USB-C in the glove compartment for dash cam recordings + media. This latest update also enabled bluetooth device connectivity (game controllers, mouse, keyboard, etc).does tesla have usb media in for music/movie files? wonder if that can be used for m&kb or 360 wireless adapter? lol
On my car the car settings like door locks, light delay, etc. are in the gauge cluster OSD and controlled by the steering wheel controls.No shit. I get real tired of cars wanting to have everything buried on a touch screen. It is fine for deeper information/controls. Like my car will let me change how it operates the door locks, do they lock when you start moving, do they unlock in park that kind of shit. That is fine for a touch screen. It is a feature you have no reason to change on the road. But for thigns like climate control, answering the phone, the radio, nav, etc these should all be easily accessible, well designed buttons or knobs.
More hate on a $120k luxury car where the tech can only be used while waiting to charge aforementioned novelty item. Is that [H]ard?Tech enthusiasts hating tech.
For that money, one could build one heck of a system and play at home, instead of on a small screen waiting to charge a car...
You think a $120,000 car is reasonably priced? Mid level as well?Salty dude calls reasonably priced mid level vehicle a luxury car.
An Altima is a reasonably priced "mid-level" car.Salty dude calls reasonably priced mid level vehicle a luxury car.
but [H] is the 12 Angry Men of tech forums, if we can't complain here where can we complain? ¯\_(ツ)_/¯
still funny to point out nerds complaining about tech though
