I know this question is asked a lot, however wanted to know if my new build is operating within spec.
AM2 X2 4600+ running stock with OEM cooler
Asus M2N32-SLI motherborad
Antec P180B Case with ALL stock 120mm fans running at medium speed (3 speed fans)
So the motherboard I know runs hot, it sits at about 44-48C under varying loads. Room temperatuure is a bit high at 26C.
The CPU idles at ~35C which is good considering it is 10C cooler than the motherboard. However if I load a single core with Prime95 the temp jumps to 51C. If I load up a second instance of Prime95 on the other core it jumps to 62C. Appears to run stable like this for atleast 6 hours (longest I tested).
Do these temps seem high and should I be concerned about the CPU running at 60+ for extended periods?
