DangerIsGo
- Apr 16, 2005
So my Q9550 @ 3.5GHz/1.208v(According to CPU-Z) under load is pushing 58C and idle is around 38C. I'm using distilled water with some PT nuke, with an apogee block (original) which was just lapped and polished, along with the CPU which was just cleaned using the arctic silver cleaner. I cleaned the block out well and got all new tubing, and a new res. My rad is a 2x120 swiftech (with built in res). I don't know what more I can do! I thought my temps a while back were much better, but apparently I was mistaken. I also have a 4870x2 block in the loop with a switch chipset block (both after the CPU) so its CPU -> NB -> GPU -> Rad -> Res -> Pump. I have the XSPC res which allows me to have dual loops (which I'm looking to put the GPU on its own loop. Does anyone think that would decrease my temps? I just don't know why they are so high and frankly, its ticking me off as I'm going through all this work and not seeing any gain.
