I was searching for BS player (a music program sort of like windows media player, but better), and after I got it and downloaded it (which was only 5kB!) I ran the program and it obviously couldn't load up. I did some research and found out I needed this bitcomet thing. Anyway, I downloaded bitcomet and then I could run that file. In bitcomet, before that file started downloading (Seems to be the original file I downloaded was not the actual BS player) I got a message saying that I needed to configure my TCP/IP Half-Open Limit. I downloaded a patch which everyone was saying was needed. But now after I was reading some other reviews, it's said that this patch is not needed, and things are actually better without it.
I got this patch from here: http://www.mydigitallife.info/2005/11/15/windows-xp-sp2-tcp-connection-limit-event-id-4226/
And this is the review which said it wasn't needed: http://forums.bitcomet.com/lofiversion/index.php?t984.html
Has anyone used this patch before? Is it needed? Or is this just bull.
Man if this is really bull, than I must find a way to undo this patch thing!
