Tablet help
Discussion in 'Mobile Computing' started by Pivo504, Jan 12, 2019.
  1. Pivo504
    Pivo504 2[H]4U
    2,149
    Feb 18, 2005
    I currently own a NuVision 8-Inch Full HD IPS 1920 x 1200 Touchscreen Tablet PC, Intel Atom Z3735F Quad-Core Processor, 2GB RAM, 32GB eMMC SSD, Webcam, WIFI, Windows 10 & its served its purpose well. However, at times it does odd things like the battery drains super fast, it has no USB port, bluetooth randomly doesnt work, wifi randomly disconnects or wont connect at all...Therefore, I plan to get something better as I got this for free at the microsoft store many years ago. After looking into a new tablet for some odd reason many of them do not support the resolution that my current free nuvision 8 inch supports which is 1920x1200 or even 1080p which is what I want. Many only support lower odd resolutions that I do not want. Would like to hear everyones suggestions I really dont want to go any larger than 10 inch as I carry this in my backpack to work everyday!
  2. 123Lanoix
    123Lanoix 2[H]4U
    3,742
    Nov 13, 2005
    whats your budget ? maybe get a surface go if you need windows ?
  3. Pivo504
    Pivo504 2[H]4U
    2,149
    Feb 18, 2005
    Well the budget would be limitless if it's possible to get a gaming tablet that uses windows :) but anyways I want something that's Def 1080p long battery life and good gpu that can play some games.
  4. Brian_B
    Brian_B [H]ard|Gawd
    1,917
    Mar 23, 2012
    Got a few conflicting requests there.
    What kind of games are you looking at when you say "some"? There's a big difference between, say, Solitare and Crysis.
    Also, do the games need to run on the pad, or are you mostly looking at using this around the house where you could stream the game (say, Steam in-home streaming or nVidia GameStream/Sheld style)
  5. Tiberian
    Tiberian DILLIGAFuck
    5,761
    Feb 12, 2012
    A first or second generation Surface Pro would work nicely. Not great battery life, not great GPU performance (Intel), not really a gaming machine obviously but either of them, or even a third gen Surface Pro with the fully adjustable kickstand would offer everything necessary and any of them can be found on eBay for under about $300 these days. If you want a really powerful tablet with gaming capability then you're gonna be paying a princely sum for one, probably $800+ and there aren't many to choose from because they'll be in 2n1 convertible format and not a true tablet (no physical keyboard).
    It'll either be a flip-style convertible with a fully swivel hinge thing where the keyboard section can fold back around the display assembly or it'll be a style where you can separate the keyboard and display and just have the display/tablet section.
    It won't come cheap, that's for damned sure.
  6. Pivo504
    Pivo504 2[H]4U
    2,149
    Feb 18, 2005
    Not intense games but games such as megaman 11, hollow knight etc. Stuff I can play on the go or while on a plane. And no I don't need to stream at home as I have a powerful desktop pc hooked up to every TV in my house lol. 800 bux is nothing if it can do what I said above at 1080p. Btw ive never tried but i don't think my current tablet can play any of the games above? lol
  7. Commander Shepard
    Commander Shepard Proud Brony
    3,073
    Apr 12, 2016
  8. Brian_B
    Brian_B [H]ard|Gawd
    1,917
    Mar 23, 2012
    iPad is going to have the best mix of performance and battery life, and has a pretty large selection of games... but it's iOS and will never be Windows.
    I think your probably going to be looking at a Surface or one of the convertibles.
    I wouldn't get too hung up on screen resolution - yeah it's important, but I wouldn't hinge my entire purchase on just that metric alone. Most of them are going to be something non-standard just because they aren't usually 16:9 sized.
  9. Pivo504
    Pivo504 2[H]4U
    2,149
    Feb 18, 2005
    Needs to be windows
  10. Tiberian
    5,761
    Feb 12, 2012
    A Surface Go as I just mentioned in another thread might be a worthy choice. Even the low spec model with the eMMC storage gets great reviews, and while it's got an 1800x1200 3:2 aspect ratio display it's still a worthy item to check into.
  11. 123Lanoix
    123Lanoix 2[H]4U
    3,742
    Nov 13, 2005
    check out the dell 2 in 1 5295
  12. 123Lanoix
    123Lanoix 2[H]4U
    3,742
    Nov 13, 2005
    i tried the surface go at the microsoft store the performance was pretty impressive based on the specs.
  13. Pivo504
    Pivo504 2[H]4U
    2,149
    Feb 18, 2005
    So is there a such thing as a gaming capable tablet that has windows? My tablet has been acting up and won't hold a charge really annoying
  14. 123Lanoix
    123Lanoix 2[H]4U
    3,742
    Nov 13, 2005
    no the surface go or pro are the best windows tablets
  15. Pivo504
    Pivo504 2[H]4U
    2,149
    Feb 18, 2005
  16. Tiberian
    5,761
    Feb 12, 2012
    Depends on the games you're talking about and yes I read the OP and the follow-up post about a few named games so consider this: if you want to play Android-based games but not on a smartphone you can actually use something like BlueStacks to do it and it usually works pretty well given the significant boost in performance that an actual desktop-class machine can offer given the limitations of the laptop-based processors and GPUs in use.
    The only way you're going to know if the device is acceptable is buy one, use it, test it out, and if it's not up to your requirements then return it and give something else a shot. If you're looking for a tablet with a discrete GPU at a reasonable cost, I can't point you to anything except perhaps a used Acer Switch:
    https://www.techradar.com/news/acer...nd-switch-7-black-edition-convertible-laptops
    Putting a discrete GPU in a tablet form factor is very very difficult considering the heat generation and the need for proper cooling while not really having the space inside the chassis for such additional hardware components. Intel GPUs nowadays on newer hardware (like 6th 7th and 8th generation Core technology) isn't so bad. No it can't match a true discrete GPU from Nvidia or AMD but then again the games you're speaking of don't require massive GPU performance anyway.
