Armenius
Extremely [H]
- Jan 28, 2014
I think it depends on the base resolution being used, which unfortunately I have not seen specified. I think for UHD 4K it uses 1920x1080, but that may differ depending on what quality DLSS you're using. 2560x1440 may similarly use 1280x720 as the base. That is how you are able to get twice the performance with it on.Does DLSS work better in 4K? I've been fairly underwhelmed by it in a lot of games at 1440p. I mean, it does definitely improve framerate a LOT, but I almost always can tell the graphical quality decrease it has.
