System Monitoring in Desktop Window.
Zer0Cool
Hello guys!
I currently use MSI afterburner to have my PC performance/temps displayed in games via top right hand corner. I want to do the same but on my Desktop in windows 10. OSD doesn't work outside gaming, is there a way to get it to always show up outside an application say the desktop? So far I can only see this while im in games, but not on my desktop outside games. I know there are programs that I can get to monitor something like that, but i need something as simple as what MSI afterburner offers, just a simple readout of my CPU and GPU temps via right hadn corner, not some application windows that I always have to open manually....
Any advice would be much appreciated.
Thank you
B00nie
Most likely the app only works on 3d rendering, not on the 2d desktop.
Zer0Cool
Thanks for that.
Any other software out there that I can maybe use to produce a similar effect? I remember when windows gadgets were available some of them had cpu/gpu readouts that would clip on the corner of my desktop.
TheSlySyl
I use https://www.rainmeter.net/
and specifically the https://github.com/SilverAzide/Gadgets skin, though they have literally hundreds of skins to choose from, i find this one particularly readable for all the information I need. Though to get fully accurate readings (mostly for GPU) you need hwinfo64 running at all time, so instead I usually use msi afterburner with the monitoring "detached" and running below my rainmeter gadgets. Go into settings and disable all the monitoring that you don't need, normally it has like 1000 graphs but I have mine lowered to just 5 that won't be displayed on rainmeter.
This monitors all my cores, most of my temps, individual programs gpu/cpu/ram usage, all 10 of my hard drives, and my network use.
Rainmeter can become a deep, deep hole depending on how much you want to customize it. You've been warned.
https://www.reddit.com/r/Rainmeter/
