system IDLE processes taking 99% of processor time almost constantly.
Discussion in 'Operating Systems' started by Journier, Feb 27, 2006.
  1. Journier
    Journier [H]ard|Gawd
    1,300
    Mar 29, 2003
    even while im writing this, its lagging my system down to a crawl.
    it comes it spurts pretty much?
    no idea why its doing this, it was fine not 3 hours ago, then i did a restart and it started doing this,
    since then ive restarted like 5 times trying to figure out whats causing it no luck :/
    programs are taking 5 minutes or more to open sometimes.
    ive booted into safe mode, and did a norton anti virus search, and an AV anti virus search.
    also i have run a spy bot search and destroy search, and im running a stinger search right now but its going so slow probably going to take another 20 minutes.
    windows xp pro
    3.0 intel processor, hyper threading.
    1 gb ram
    200 gig main hard drive
    40 gig backup.
    ... I just recovered from some sort of odd virus last week.. which didnt act anything like this.
    ever since ive recovered from that last virus, ive been running Zone alarm 24/7, with high/high settings for blocking stuff.
    and now this happens
    once again thanks for any help.
    Nothing has been found yet.
    0 spyware
    0 virus's or trojans yet.
    why is system idle process taking up all my processor power? it doesnt make sense.
    can i turn it off? i dont care about what it does, id like to turn it off, since its running constantly.
  2. upriverpaddler
    upriverpaddler [H]ard|Gawd
    1,705
    Jun 11, 2004
    ??Is it April Fool's already??
    Post a screenshot of your Task Manager when it is happening.
  3. Forthy
    Forthy Limp Gawd
    202
    Mar 16, 2003
    You're joking, right?
    [​IMG] [​IMG]
  4. Whatsisname
    Whatsisname [H]ardForum Junkie
    10,220
    Nov 15, 2000
    holy jesus not this again
  5. Drudenhaus
    Drudenhaus 2[H]4U
    3,125
    Sep 27, 2005
    Is this a joke?
  6. Journier
    1,300
    Mar 29, 2003
    ? no its not a joke?
    heres the thing i just double checked system idle processes, is showing 99 under cpu
    but when i go to cpu usage statistics, its only showing 2 %
    every program i have is taking forever to start.
    sigh. Stinger never found anything either...
    any reccomendations?
  7. pxc
    pxc [H]ard as it Gets
    33,112
    Oct 22, 2000
    "IDLE" is the do-nothing state. It's normal for the OS to be in idle mode when it's not doing anything. :p
    Anti-virus programs set to the highest state slows many computers down to a crawl since it scans everything. Little memory (i.e. 256MB) compounds that problem several times over.
  8. Asian Dub Foundation
    Asian Dub Foundation [H]ardness Supreme
    7,944
    Aug 1, 2005
    *trying not to laugh* yup system idle means ur cpu is idling... so 99 percent is a good thing
  9. Drudenhaus
    Drudenhaus 2[H]4U
    3,125
    Sep 27, 2005
    If the idle process is using 99% of the CPU...then your CPU is only being 1% utilized and the other 99% is doing absolutely nothing.
  10. Journier
    1,300
    Mar 29, 2003
    ok then, hmm
    i assumed it was the other way around?
  11. TheGamerZ
    TheGamerZ [H]ardness Supreme
    5,217
    Sep 18, 2003
    Just to confuse you
  12. hulksterjoe
    hulksterjoe older and wiser now
    2,919
    Jan 1, 2001
    look at it in reverse...99%idle means you've got99% of the cpu 's ability available..the other programs will show you what percentage of cpu time they are using..so if you have a program that is maybe just monitoring like antivirus it'll show zero and then amybe jump to 7 or 10 for a split second and them back down to zero
  13. TheGamerZ
    5,217
    Sep 18, 2003
  14. Journier
    1,300
    Mar 29, 2003
    ok so i was confused you are correct, but its still very odd why my computer is lagging up so badly. it cant be processor, so something is accessing my hard drive hard core.
    And i do fold, have 2 computers that fold.
  15. MorfiusX
    MorfiusX 2[H]4U
    3,007
    Feb 13, 2004
    A failing hard drive can cause the symptoms you are describing.
  16. djnes
    djnes [H]ard as it Gets
    19,577
    Mar 24, 2000
    I can think of a few...but I'll post only one:
    [​IMG]
    If not on here, atleast google it. Had you googled "System Idle Process", you would have avoided the previous several people laughing at you or asking if it was a joke.
  17. Phoenix86
    Phoenix86 [H]ardness Supreme
    6,658
    Mar 28, 2002
    I'm trying a new approach. I simply link to a google search of the thread title. It's so quick and answers quite a few of the threads, generally it's one of the first 5 hits. :(
    See
