I think this is a well known problem but I coulnd't quite locate it using the search button so I thought I'd just ask. When my comp boots up its pretty quick except for when it gets to the Windows Xp splash screen where the little blue things dash go back and forth. It seems to hang there for awhile. Now I may have installed the nvidia IDE driver. Should I just use driver cleaner pro and fix it. Which driver should I install instead of the nvidia one. I have Nforce4 Ultra.
