So I am trying to decide how I want to proceed with my setup. I have 4, 2TB harddrives sitting here that I want to share to my network.
I have a HTPC mini box that is attached to my TV that currently runs xbmc, etc.
My setup is a Wifi G router with no real way to do wired networking...my HTPC has shitty wifi N (only gets 30mbps throughput on an N network) but I have never had problems streaming content to the raspberry pi I have upstairs.
I am trying to decide if I should get a synology ds 1512+ (5 bay NAS) or whether I should buy a asus ac55u and hook a JBOD sata enclosure to it. I'm concerned the synology is overkill for what I need.
I want whatever I connect to be able to exist as one big folder on the network -- I dont want multiple drives. Will I be able to mount a JBOD array onto the asus router and share it all as one drive? Or will it separate out?
I don't really care about parity/backup. If a drive fails it wont be the end of the world. I've heard that with JBOD you only lose the data on the lost disc as well.
I guess the main thing here is cost. The synology was about $600 and if I have to buy an AC router to go with it anyway thats another $130-$200. If I just do the router and mount the shared drives there that is only $100 for the enclosure.
Another thing -- does anyone own an ac1750 router? It would seem to me that there are almost zero 1750 wifi adapters available for purchase. The only one I could find was an asus PCIe card ($100) and the next fastest are ac1200 usb adapters. No usb 1750 adapters at all.
Anyway...can anyone share their experience with this sort of stuff?
