Mark Rejhon
- Jul 6, 2004
Right.you can buy super expensive good LCD to minimize LCD issues to minimum or buy cheap Trinitron CRT and minimize CRT issues
Viewpixx LCD (five figure $), or Eizo FDF2405W (four figure $) comes to mind.
Are you familiar with phosphor ghosting on medium/longer persistence CRT's? Remember the old radar tubes at air traffic controllers? The ones with the spinning line? That's intentional extreme ghosting on a CRT. An extreme case of longer-persistence phosphor, mind you. Phosphor closer to the type found in glow-in-dark toys. But even short/medium persistence in monitors, the phosphor still glows for a bit -- just millisecond timescales, not minutes/hours timescales. This creates phosphor ghosting if the phosphor isn't fast enough, and the motion is fast enough on a bright edge on a black background.Are there really any CRT that actually do have green trails?
Some CRT monitors such as Sony FW900 use medium-persistence phosphor, and have minor ghosting that is seen during very fast bright-on-black motion such as www.testufo.com/#test=blurtrail&thickness=8&height=-1 -- you'll see a minor CRT ghosting trail on the Sony FW900 (use full screen mode, turn off all lights, and scroll the window to only show moving bar), as an example. This phosphor ghost becomes dramatically more visible if you use maximum brightness (on a fresh CRT at least), and becomes much better at lower brightness. As FW900 is a bigger widescreen CRT computer monitor with such a fine grille pitch relative to screen size, it needs a slightly slower phosphor than an average CRT television, in order to keep brightness sufficiently high. Very minor ghosting also happens with this test pattern on plasmas (but ghosting is much shorter and smaller; and yellowish-colored instead, on the trailing edge). The ghosting behavior is very different from LCD's, and is a function of the glow-in-the-dark phosphor decay effect. (Like a glow-in-dark toy, but on a much faster/shorter timescale).
Although ghosting does vary on LightBoost monitors, there is less motion blur and less ghosting on XL2420TE/VG248QE/XL2411T, than on a Sony FW900 CRT which isn't the fastest CRT in the world for motion blur, but it shows how the fastest LCD's can outperform (blur AND ghosting) some of the slower CRT's such as Sony FW900's. Generally, a FW900 will have far better blacks and colors, and FW900 are nicer in many aspects (resolution independence), but today as of year 2013, it's no longer true that all LCD's always have more blur/ghosting than all CRT's, because the ghosting & motion blur performance overlap happened recently. Certainly, some LightBoost monitors have had bad LightBoost double-image-ghost artifact (e.g. certain VG278HE units, older XL2420T's, etc), especially with fine checkerboard-pixel-patterns, but that's not true for all LightBoost monitors.
If your W900 or FW900 is performing perfectly, great blacks, bright colors -- keep it running well.
Certainly not disagreeing that the "The best CRT's outperform the best LCD's" statement, which is true in terms of blacks and color.
But I'm correcting the "All CRT's always outperform all LCD's in ghosting and motion blur" statement.
Correct, colors are not as good as a pristine, well-calibrated CRT. I know, as I've owned CRT's for many years, and owned a NEC XG135 CRT front projector with a 92" wall projection screen. Imagine having a CRT with over 20 times the effective surface area of a GDM-W900! CRT's are becoming fewer and fewer alas, with LightBoost outperforming a failing FW900 with worn flyback transformers, with grey-colored blacks, blurriness, and poor colors.Unfortunately picture quality of such LB monitor is nowhere near picture quality of CRT...
For many former CRT users, often a decision must be made; do you repurchase a monitor on Craiglist/Kijiji/eBay, or switch to LightBoost, or to IPS, etc. And OLED isn't yet a suitable heir just yet (burn-in, motion blur) while they're refining that technology. There are many FW900 users that say their LightBoost is better quality (in all aspects, black levels too, colors too) than the Sony FW900 they replaced. That's a testament to how worn-out a well-loved well-used FW900 can become; and it's hard to constantly replace them.
That said, if you get CRT eyestrain, definitely steer towards a PWM-free LCD instead of LightBoost. LightBoost is really good if you really loved high-refresh-rate CRT's, and didn't get eyestrain from them, and you want something easier/lower maintenance (especially in a larger widescreen format). But I know there are many use cases where a PWM-free monitor can be more appropriate -- software/web development, browsing, etc.
Again this link shows how big-time a CRT owner I was, as well as I also worked in the home theater industry too, as well.
