Current setup: Windows Server 2008 R2 with WHS v1 as a VM
Issues:
- slow read/write in WHS
- perpetual fear of server drive failure in WHS
- Hyper-V bugs causing the occasional issue
- Inability to hotswap drives in WHS (must power down the VM to do add)
Overall, this system is 99.9% reliable and problem-free. However, my fear is that it is unnecessary levels of complexity that will make fixing a problem down the road more difficult.
PROPOSED PLAN: Just use basic drives in Server 2008 and use SyncToy to copy data daily as a backup (I currently use duplication in WHS for everything)
I would be giving up the convenience of the file type divisions (e.g., movies, tv show, etc.) but really 99% of my time is accessing it through XBMC where having to add a few additional file paths isn't a big deal. It will also be easier to log what is on each drive in the event of failure (i.e. if I lost a data drive and its duplicate and needed to re-rip DVDs, etc.). Plus, while WHSv1 drives *technically* can be tossed in any computer and read as NTFS, the random (read: moronic) way that files are divided across drives makes it very difficult to pull data unless you have space to pull ALL the data.
Any last thoughts or concerns re this setup before I dive into it? It is about 9TB of data I will have to start converting over.
Issues:
