Swapped to a 4070ti, and weird boot
jordan12
So i had a vanilla 4070 and bought a used TI. I used the power adapter that came with card. the right light next to the power connector goes on. looking it up shows either bad adapter or bad card. I asked the seller to take it back.
Two desktops show the same problem
Apologies. I had to do it. :D
Does the PC stay on or does it shut down? What are the specs of your PC?
Had a similar experience a while back buying my current card. I plugged in the adapter that came with card and it was unused by its former owner. Fans 100% on boot with card rgb lighting up, solid red fault LED and no video output. It did indeed end up being a faulty power adapter that was RMA’ed. I wish you good luck.
