Hold down the space bar and move the mouse around. I know there's a way to set alternate view angles as well, but I don't know what the command for that is off the top of my head.Anyone know if it's possible to rotate view of the battlefield? The arrow keys move the view field left, right, up, and down, but I'm guessing there's also some way to rotate the view?
Is there a way to lower building time of units? Because building a battleship is ETA 18 min
Resource use per tick is basically (total resource)/(base build rate for builder).18 min is nothing. A nuke silo is 80+min. Use Support commanders as they build in half the time, but use more energy when building. I had about 13 of them and I built a silo in like 10 min( actually time unknown but it was fast).
SCUs build faster than T3 engies, so they use more resources. Upgrade your commander for build (2 upgrades give him faster speed AND T2/T3/T4 capability) and it is the fastest builder in the game, twice an SCU, IIRC. The SCUs also have a build speed enhancer for even faster building.
And yeah, nuke silos take hour or more base and mavors take, well, several hours (unassisted).
I'm starting to get some slowdowns on the lappy, with about 100 units total. I'm totally maxed out at 1920x1200, highest details.
I'm wondering what would be more effective - lowering res, or dropping ing game settings?
Ahh. Poor baby.I'm starting to get some slowdowns on the lappy, with about 100 units total. I'm totally
'How do I defend against tier 3 arty. I havent had it used against me but im thinking of trying hard difficulty and want to know how to defend my base from being destroyed if the AI uses it.
stealth gens....unless they have a T3 radar....then just craploads of shields
cose to almost the whole map(stealth detection goes with that), i think it cover 20x20 fully, so on the larger maps you might have to make some extra radars....not to mention those T3 radars take a crapload of energyDoes T3 radar cover the entire map for stealth detection?
OK, finns revenge is a 5x5 map. omnis have stealth detection to 3.9km, and normal radar to 11.xkm (and sonar to the full radius).cose to almost the whole map(stealth detection goes with that), i think it cover 20x20 fully, so on the larger maps you might have to make some extra radars....not to mention those T3 radars take a crapload of energy
true. Long as you have seen the building it will show forever.stealth generators dont work if its a building that has been scouted though.
Lower the res and put the details on medium, more then likely your laptop bottleneck is the video card. Which is needs to be less strained.
As far as I know, SupCom just reads the resolutions available from the graphics drivers. If that is indeed the case, you'll just need to add that specific resolution via your graphics control panel and SupCom should have it as a selectable resolution.I plan on dragging the lappy out to the HDTV tonight and seeing if the drop from 1920x1200 to 1366x768 does anything for it. (assuming supcom can handle that specific res, we'll see)
I dropped to 1600x1200 and dropped everything to low and got 30 fps last night. I think it may be time for the beast to be built.
Is there some kind of civilization map/tree out there? Or does anyone know the differences between the 3 civs?
Another good one (with some different information) is here: http://147.28.0.58/supcom/Here is a good unit database for SupCom
http://www.supcomuniverse.com/unitdb/
