It seems that the X10SAT has finally arrived? It is "in stock" here:
http://www.superbiiz.com/detail.php?name=MB-X10SAT&show=p
Thanks for the info, I will wait for combo with a xeon at newegg.
Are you concerned of data corruption on your files? If so, I assume you use ZFS then?
+1.If you're going to come out with a comment like that then at least explain your reasons and back it up with some evidence. What exactly did he say that was incorrect?
Can anyone link to a few 8GB ECC RAM sticks on newegg?
Just got an SAE today and realized it wouldn't boot, at least I couldn't get it to, without a graphics card (using a xeon).
I guess there's no IPMI either?
I didn't see any indication of C1 vs C2 in bios. I'll report back when I get far enough to check that.
Is this a real concern or has it been corrected in BIOS updates?
Newegg must have had a few returns of these boards since the open box version is being offered at $153, a $62 discount. Please let me know as I am looking to buy soon.
I'd like to change to an X10SAE instead -- but only so long as my 510RPM (at idle) CPU cooler doesn't trigger that crazy fan cycling.
cpu0_vid:0
grep: driver: Is a directory
fan1_alarm:1
fan1_input:0
fan1_min:200
fan2_alarm:1
fan2_input:0
fan2_min:200
fan3_alarm:0
fan3_input:507
fan3_min:200
fan5_min:200
... snip ...
Note: the logical fan numbering does not match the printed numbering.
Has anyone received a new X10SAE with C2 stepping on it yet? All the C1s should have been cleared out by now.
