It's not a ten year old server because I just build the thing in 2018
If you built that in 2018 you made poor choices. 9 years old. We’re done here.
Poor life choices.and upgraded it several times before 2022,
Because that is ALL THAT MATTERS.so what if the internal hardware is from 2013
He isn’t buying that. None of us are. Almost no one is.when Dan_D is willing to take an Intel 2011v1 system for $508
Case doesn’t matter. Unless you want a rack mount. Sell the chassis and be done with it.with just one hard drive that costs more once fully configured and you only showed me an Intel 2011v2 system for around $600 in a desktop computer case
Hot swap bays are cheap. The chassis has some value. Sell it and be done with this.instead a proper rackmount chassis or pedestal with hotswap bays.
So 1500 more and 25x as capable.Even your post on the first page was a Xeon Scalable fully configured for over $5000
Liesand I already showed that a 2U Dell would cost around $7000 or more
A “fully” configured server would blow your mind.and it wasn't even fully configured, so it might as well cost $10000 or more because that's probably how much it would cost with Intel Xeon Scalables once fully configured with the price of SSD's instead of mechanical.
NoYes they do cost $10000 or more once fully configured minimum
Nofor a 2U because I showed it somewhat configured for around $7000
Noand it wasn't even fully configured, which after you add SDD's for Dell's insane price
Faster than what you are sellingit will probably cost you over $10000. All you're getting with that so called $1000 is a Pentium G6405T,
You think rack units matter? Are you even remotely educated here?one 1 TB harddrive and the motherboard starting at $1019, which once fully configured probably costs more than what I'm selling and it's not even 2U.
You don’t know what that meansThe $508 server you showed me wasn't even fully configured either
No one cares about drives.and only had one hard drive at $508
2.5” drives go to 30TB+ now. Seriously. You’re out of date., which after it's fully configured with six 2TB SDD's if 2TB SSD's are even an option considering it only hold's six 2.5 inch drives
No.and not eight 3.5 inch or 2.5 inch plus I'm including eight 2TB HDD's it would probably cost more that what I'm selling.
