Bad news and I'm not sure how to solve it. I flashed the bios again and now it won't post at all, I tried following the Supermicro steps for recovery, but it's not working. Any suggestions what to try?
Seven10, what's the news? We're with you on this,let us know!
Hi tear. I find some motherboards like to increase vcore (0.05V or more) quietly by themself. For example, I manually set the vcore to 1.000V but the value I read with system vcore sensors would be about 1.052V, while the VID value I read is unchanged so it's not affected by the max VID limit.
Is it possible to add such functions to the OCNG BIOS? This would GREATLY improve the OC ability of stock chips.
Ok, then I'd recommend that you do this:
1. Power-Off (pull the plug)
2. Disable IPMI (jumper)
3. Power-On
4. modprobe w83795
5. wget http://darkswarm.org/voltcheck.sh
6. chmod +x ./voltcheck.sh
7. ./voltcheck.sh
8. Observe results![]()
According to this description, seems the memory frequency would downgrade to 1066Mhz? But under the stock BIOS it’s running at 1333MHz. Did I misunderstand something?Supported memory configurations:
DDR3-1333 or faster: refclocks 200 through 250 (effective DDR3-1066 through DDR3-1333, respectively)
DDR3-1600: refclocks 251 through 262 (effective DDR3-1339 through DDR3-1397, respectively)
Hi, I have a question about the memory frequency behavior under OCNG BIOS.
I'm currently using 1.65V XMP 1600 memory sticks. These sticks are unable to apply the "16" flag, right? Then I'm wondering what frequency it would be running under the OCNG BIOS (with ./smocng.sh 200)?
 MTB values (such as Crucial's DDR3-1866 modules) will be supported in OCNG4
It will happen this weekend if nothing interferes...Supporting DIMMs of higher frequency would be great! It becomes more and more hard to find low latency 1600 DIMMs nowadays.
Hope the OCNG4 BIOS could be released as soon as possible.![]()
For 241-250 it doesn't matter. For 251+ -- 1600.( 1333 c7 1.5v ) vs (1600 c8 1.5v) --> which one is better for 4p OCed rig (refclock > 245) ?
Price difference is so insignificant I'd opt for DDR3-1600 CL8 or even (future-proof) DDR3-1866 (with OCNG4).
ROM has been reworked so it can accommodate new code.Hi tear. Can you say something about the progress on making overclocking bios for Interlagos CPUs?
$ sudo ./ocng-cu
ocng-cu: OCNG configuration utility (NG4)
Detected board: 'H8QGL'
Reset OCNG configuration to defaults (no/yes) [no]?
Reference clock (200-262) [240]?
Configure advanced options (no/yes) [yes]?
Perform multiple refclock sets (not recommended) (no/yes) [no]?
Configure refclock on warm reset only (not recommended) (no/yes) [no]?
Dynamic HT configuration (not recommended) (no/yes) [no]?
Prevent use of XMP profile 1 (no/yes) [no]?
Allow effective memory frequencies above DDR3-1333 (no/yes) [yes]?
Allow unsafe CAS latencies (not recommended) (no/yes) [no]?
Force 1.5V DIMM Vdd (DANGEROUS) (no/yes) [yes]?
Use alternative HT tuning (no/yes) [no]?
Relax memory timings (no/yes) [no]?
No roadblocks so far. The only issue is lack of time...
Code:$Detected board: 'H8QGL' Reset OCNG configuration to defaults (no/yes) [no]? Reference clock (200-262) [240]? Configure advanced options (no/yes) [yes]? Perform multiple refclock sets (not recommended) (no/yes) [no]? Configure refclock on warm reset only (not recommended) (no/yes) [no]? Dynamic HT configuration (not recommended) (no/yes) [no]? Prevent use of XMP profile 1 (no/yes) [no]? Allow effective memory frequencies above DDR3-1333 (no/yes) [yes]? Allow unsafe CAS latencies (not recommended) (no/yes) [no]? Force 1.5V DIMM Vdd (DANGEROUS) (no/yes) [yes]? Use alternative HT tuning (no/yes) [no]? Relax memory timings (no/yes) [no]?
Cause of this issue is unknown. No investigation has been done to date.One question about IPMI: why it cannot work together with the OCNG BIOS on GL boards?
