Sunbeam front panel missing power cable - what kind of power cable needed?
davidm71
Hi,
Got an old Sunbeam 20-in-one front panel multifunction panel and it needs some sort of a micro molex adapter to power the device which I lost. Not sure what kind or where I can find one to buy. Mod-Diy sells pitch cables that look like it. Not sure...
Thanks
The Mad Atheist
Hi,
Thanks
Is this the 4 pin molex that old floppy drives used?
Post a pic just in case I can't find the front panel online.
Edit:
THIS? v
https://www.amazon.com/Sunbeam-Superior-Panel-Reader-Controller/dp/B0009F4Z20
davidm71
Yes that is it. Heres a photo:
It is the third plug from the left.
The Mad Atheist
I not sure on the connector plug type, Sunbeamtech is out of business, worse come to shove, you have what's 5v, Grd, and 12v.
See if the pin spacing is same as those 3 pin fan headers, you might be able to modify a 4pin PWM CPU hs/f cable.
Or if you know how to solder, replace the connector on the board with a old 4 pin molex.
The Mad Atheist
See if you have one of of these type of connector so you can if it has the same pin spacing, you can use a 1x4 - 1x2.
