Mansize_tissue
- Jan 1, 2007
BTW, there is another contender that you might want to look at. Right in front of me i have the AudioTechnica ATH-A700 closed headphones. Some people say they are your best choice for un-amped operation. Very clear sound and good comfort levels. Very even tones from low trhough mid over to high range. The price is right as well.
And just as i had decided on the DT 770 Pros.
Hehe, thank you for mentioning them. I came across them earlier, but just passed them by; do you think i should get these over the DT 770 Pros? I'm doubting whether the Beyers will work very well without an amplifier; does anybody have any information on this, because it's the only thing putting me off?
Thank you, Blu_Haze, that was most helpful. I had no idea the only difference between the X-Fi Xtreme Music and X-Fi X-Fi Fatal1ty Professional was the added X-RAM. I really don't know what sound card to get. In my situation, is there any point getting the Champion version, because all i want it for is to be able to plug my headphones into the front panel. However, if the same quality can be achieved by using the front audio ports on my case, i can opt for the cheaper Professional version. The headphones will be just as good plugged into the audio port on the front of my case (as long as that is plugged into the sound card), right?
But then, i suppose, if i don't need the front i/o panel i could just get the Xtreme Music card, although it would be nice to have the better Fatal1ty card, since i'm likely to have it for years.
Can anyone with the Champion version of the Fatal1ty card tell me if the front i/o panel is worth getting, if i'm just using it for my headphones?
Thanks again, i can't tell you all how much help you've been!
