I was running "blend" test via Prime95 when I heard this pop followed by a burning smell. Crazy thing was, the system kept on going without missing a beat. Prime95 kept on running, fully stressing all 4 cores, with the system showing no signs of any stability issues. I stopped the program and turned off the system anyway since I didn't want to risk damaging my system any further.
Some system details at the moment of "pop".
- ASUS Rampage III Formula motherboard
- Core i7 920 running at 4.4ghz (210x21) @ 1.35v
- RAM at 1683mhz (8-8-8-24 1T) @ 1.65v
- CPU PLL voltage @ 1.91v
- QPI/DRAM core @ 1.44v
- DRAM Bus @ 1.65v
- IOH (NB) voltage @ 1.26v
- CPU temps maxed out at 78c during "blend" test via Prime95.
- All other temps were good with NB and SB at 48c and 42c, respectively. I monitor all system temps religiously during stress testing and did not see anything out of the ordinary.
I immediately suspected the PSU, but had my doubts since it's pretty robust Thermaltake Toughpower 1200 watt'r. Took a flashlight and looked for possible busted capacitors inside the PSU but I couldn't find any and some were hidden from view. I then started look for possible busted/bulging/popped capacitors on the motherboard and the two GTX 460's. Nothing. My nose was still picking up a faint burning smell coming from the system but I could not find anything. No busted caps that I could see and no signs of any damage.
So, I powered up the system... and it posts. Everything looks good to go and the system boots all the way. I ran 3DMarks Vantage to see if there's anything wrong with the graphic cards. I get the highest Vantage GPU score that I ever scored with perfect graphic rendering on these moderately overclocked GTX 460's - 29,997 with physX off. WTF...
I was still scratching my head at this point. All of the attached peripherals and hard drives were working. Core i7 920 was running perfectly at 4.4ghz before the pop. I considered just leaving the system as it was since it was running fine, but my rational side took over and I decided to completely take the system apart and inspect the components one by one.
First the PSU. I considered opening it up to get better look at the caps, but that was going to void the warranty. I was suspecting the PSU as it seem like the most probable culprit but I could not pick up any burning smell. Gathered all of the necessary RMA information just in case.
With all the components and cables off the motherboard, I started inspecting every capacitor one by one with the brightest LED flashlight I have, my HTC Droid Incredible. The LED's on this phone is literally about 3 times brighter than my actual flashlight. It's freaking awesome. Anyway...
I inspect each cap carefully. Initially I see nothing. Then, a rounded top of a capacitor catches my eye. It's in the worst possible location ever - right below the heatpipe going from the NB to the mosfet heatsink. No wonder I kept on missing it...
Two capacitors, sitting side by side, was blown out. Upon closer inspection, the rubber seal was clearly visible at the bottom of one of the caps because the metal cover had popped off.
I'm still trying to figure out why the caps popped. My temps and voltages were well within limits, imo. I hope ASUS did not resort to less than reliable capacitors due to cost cutting measures.
So... the motherboard is on its way back to Newegg. I am hoping that the replacement Rampage III Formula does not have the case of exploding caps again.
- DRAM Bus @ 1.65v
