Just bought retail home premium. Though, my computer currently has XP on my Raptor 74GB. I also have Vista RC1 installed on another drive's partition. XP's drive is C: and Vista is D: at the moment
I want to move XP off the Raptor so I can install full Vista onto that drive. I just used used Casper XP to copy the drive with XP to another disk, currenty labeled as F:. Though, it had one file it couldn't copy it said, some boot record.
Now that it's copied, I'm confused how to disable the original XP on Raptor C: and let the copy on F: to take over. That way when I reboot and the Vista RC1 dual boot screen comes up, the earlier version of windows option goes to that drive. Which once I get into that XP I'd install Vista while in it to the Raptor C drive. Not sure how it will handle or notice the Vista RC1 on another drive.
Right now under disk management here's the status of the drives:
Original XP (C: ) STATUS: Healthy (System, Active, Primary Partition)
Vista RC1 (D: ) STATUS: Healthy (Boot, Page File, Crash Dump, Primary Partition)
Copied XP (F: ) STATUS: Healthy (Active, Primary Partition)
So, how on earth do I get my computer to make the copied XP take over for the original XP so that I can run off that and install Vista over the original?
