I have a bunch of public shares (no username, no password) hosted on a Windows 7 Ultimate box on my network
From CentOS 5.8, I can mount them manually just fine using this:
If I try to make the same thing happen in /etc/fstab, I change the syntax to this
In this mode, all I see is:
Like I mentioned, this works when I mount manually, so I know I can ping the host by name and I can access the shares. I just need to figure out how to do it with fstab since I have about five others shares I _also_ need to access this way.
I've spent quite a bit of time today twing to get this sorted out and now I'm just frustrated. Am I missing something obvious? I've hit just about every hit in the google searches and while they have good information, none have helped me.
Code:
mount -t cifs //atlanta/binaries /resources/atlanta_binaries/ -o user=guest,password=""
Code:
//atlanta/binaries /resources/atlanta_binaries guest,_netdev,rw 0 0
Code:
mount error 13 = Permission denied
Refer to the mount.cifs(8) manual page (e.g.man mount.cifs)
