Stuck on new PC build, need case recommendations
hawk82
It's been 6+ yrs since I last built a new PC and am definitely due for a new rebuild. I went to Microcenter a couple of weekends ago and got all of the components (Asus Maximus 7 Hero, Intel Core i7-4790k CPU, Crucial Ballistics 16GB RAM, 512GB Crucial MX100 SSD, Asus BD-RW (just because), Corsair H75 CPU cooler, Corsair CS750M PSU, and an EVGA GTX750ti video card that I may return (am not sure if it is significantly better than the GTX560ti I currently own). I looked at the cases they had in the store (a LOT more than they used to carry in their Boston store) but couldn't find one that I liked. They don't carry Lian-Li cases and I didn't see any aluminum midtower cases.
I brought all of the components home, did some online research, and purchased a Lian-Li PC-10NB case that I thought would meet my requirements and likes. However, once I got it delivered I realized that I don't think this case will work for me.
Issues that I have with the case:
  • No cable management/routing (major issue)
  • Aluminum feels much thinner than my current Lian-Li PC60BPLUSII
  • No reset button (minor complaint I guess)
  • No 3.5" external drive bay for my media card reader (minor complaint as I found a discontinued Lian-Li 5.25" to 3.5" drive bay adapter for sale at FrozenCPU)
  • A few sharp edges inside the case
  • No motherboard tray (minor complaint)
  • No window (I really like the one I have in my current case)
  • No way to mount the radiator for the Corsair H75 CPU cooler (major issue currently)
Is Lian-Li just not making good cases anymore? I really want a clean looking case (none of that gawdy-ness or "cool looking" front panel) with no front door, with minimal to no plastic, aluminum construction, black colored case. Am I asking for too much?
I've looked at Silverstone cases as they have some clean looking cases, but none are full aluminum, only aluminum or plastic fronts.
Here's a couple that I'm not sure about:
http://silverstonetek.com/product.php?pid=324&area=en
http://silverstonetek.com/product.php?pid=325&area=en (seems as close to what I am looking for)
I've looked through Newegg at other case manufacturers but couldn't find anything that looked nice.
Suggestions?
mangapc
That is going to be a tough case to find. Most all aluminum case cost a good amount of changes. The one you have from Sliverstone look really good. I would probably go with the TjJ04-E (http://silverstonetek.com/product.php?pid=325&area=en) of it was my money. You might just have to look around for a bit. There was a few at CES that will be hitting the market soon so don't know how long you can hold off.
I just upgraded myself. I went from and AMD 8350-FX to and Intel i7-4790K. I switched from a Fractal Design R4 to a Fractal Design Node 804. I am very satisfied with the new build. Will upload pics later today.
Fenris_Ulf
I have a Corsair C70. It's not aluminum, but it's tough as nails and pretty awesome in every way.
mangapc
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133277&Tpk=11-133-277
Does not come out till feb, but still a awesome case that was at the recent CES!!!
hawk82
I ended up getting the Silverstone Temjin case.
Was easily able to attach the Corsair H75 radiator to the rear 120mm mount. Lots of cable management and room behind the motherboard to store slack on cables. I moved the 2.5" drive bay from the stock location into the 3.5" drive bay as I plan to only have a couple of 3.5" drives and there is plenty of room for all. That frees up some room in front of the PSU and it just looks cleaner anyway.
