ochadd
- May 9, 2008
Any recommendation for a streaming device? I'm open to buying one or multiple. The whole streaming device ecosystem is confusing as hell to me. The product naming and lack of transparency in the hardware seems intentionally opaque. Roku 4k is better than Roku Express 4k+... Stuff like that. I understand that the new Google device isn't going to run the newer SOCs, sandbagging for a "Pro" device at some point.
Today I'm using an "Amazon FireTV with 4k Ultra" box from 2016 and a "Chromecast with Google TV". Both are getting slow and having issues, so deciding what my next device will be. Leaning towards a "Google TV Streamer" coming out September 24th but would like a reality check/confirmation on what makes sense. "Roku Ultra" seems decent but I think it's two years old, circa 2022.
Amazon stuff looks noticeably better on the Amazon device I have and that tends to be where we rent movies from. Get allot of unsynced audio and stutter now-a-days. The Chromecast is the more heavily used device for everyday streaming and casting from Android phones.
I don't pirate anything and have near zero media library. Don't listen to music often. Subscriptions to nearly every video service I've heard of other than Hulu. My wife watches allot of TV and is non-technical.
Denon receiver outputting to a single 4k Sony television and 5.1 speaker setup.
Dish Network satellite service alongside the streaming devices.
Have a Logitech Harmony Smart hub that can control all devices, in an ideal world. It's sketchy but a problem for another time.
Have no devices from the Apple ecosystem.
The difference of a $100 in price isn't a concern for me. I'd be willing to install full blown desktop w/ GPU if it made sense and just worked. I understand the situation to be suckier than just buying a streaming device.
Edit update:
I've been using the Google TV Streamer for a couple weeks now and it's an improvement all around over the Chromecast. Have them both connected to the same receiver so have seen them side by side. The Streamer is noticeably faster. My wife will sometime select the wrong input and you know immediately.
Moving around the menu and launching streaming apps is very good.
Paramount+ subtitles doesn't have to be enabled on every episode, every launch, like the Chromecast.
My wife thinks the picture is better but I haven't noticed a difference.
I initially connected it with ethernet but some stuff didn't work but have now forgotten what it was. Don't think it would stream from phone and a couple other things. Moving to wifi fixed them all. I have no neighbors and a solid wireless network so wasn't an issue.
It has a much larger physical footprint compared to the Chromecast but have an AV area so it's a non-issue.
I can't get it to work with my Logitech Harmony remote whereas the Chromecast did. Not in the library and assume it never will be.
I can only run at 4k 30 fps w/ HDR. Never could get 60 fps working with the Chromecast or Amazon devices and still can't with the Streamer. Not sure if it's the TV, in-wall HDMI cable, or receiver. I'll swap the cable out whenever I upgrade televisions. 60 fps looks weird to me for TV/movies so it's not something I'd probably enable anyway, but I'll fix eventually.
I think it's a nice upgrade and all the streaming apps I use it for work fine. Netflix, Prime, Paramount+, Discovery+, Max, Youtube, and Apple.
Edit update:
