Well yes, but there are four sides. At 55W per side, you get 220W total.
And there are two device which if maxed out, will probably pull close to 300 watts combined. Your point?
That link goes to a review of four different heat sinks.
This is the only review using more than 1 panel I am aware of. It does not manage to cool a 88W cpu properly. My own experience is similar.
Besides putting too much total tdp in the case the above build is never going to work because a RX570 is going to shut itself down as soon as you put some load on it because it can never run without proper vrm cooling. A few heatsinks on the vrm's in a hot box will just not work, been there done that.
Found his posts, looks like cpu is working okish, don't know how good the aida stress test is. His temp were 92 after 30 mins but still rising.
https://www.reddit.com/r/pcmasterrace/comments/2whyho/stress_test_aida64_vs_prime95_very_different_temps/
They shouldn't pull 300W combined. If they do then you've chosen the wrong components. The TDP of a stock RX 470 is 110W which is on the limit. The CPU should only be pulling 65W. That's a total of 175W, well within the 220W limit.
Well TDP isn't the whole story. Here is the RX 470 tested. It's using up to 144 watts at stock speed.
http://www.tomshardware.com/reviews/amd-radeon-rx-470,4703-6.html
30 watts over the limit on dual panel setup.
You do realise that that's an overclocked card, don't you?
It is still only rated as a 120W card, yet draws 144W.
Umm... no. The standard 470 has a TDP of 120W. TDP is not the same as power drawn.
For pure aesthetic reason, the cabling SHOULD come out of the bottom, and one should drill a hole on the cabinet where the DB4 would be sitting, so you can look at it from all angles, and "look Ma, no cables!" If finding yourself always have to plug in an external USB device, can always make yourself an external USB jack from a male-female cable and mount it on the cabinet a little away form the DB4, and preserve the aesthetic.I really don't know about the decision to put the motherboard's ports side down, making it harder to plug in ANYTHING without having to lift up the case every time. Should have reserved one side face to be the back of the machine.
The G4 Cube was a tad smaller, like a kleenex box, and notoriously for over heating. Jobs had a fetish for see-through plastics at the time, had they used heat pipes, it may had been more successful.I know it's a totally different critter, but it reminds me of this: Mac G4 Cube.
He also hated fans. Cuz that's a smart attitude with computer heat levels.The G4 Cube was a tad smaller, like a kleenex box, and notoriously for over heating. Jobs had a fetish for see-through plastics at the time, had they used heat pipes, it may had been more successful.
