Stratos 3: ~3.5L PicoPSU Chassis
thehack
Hello SFF lovers. This post is for my custom 3.5l acrylic case. I intend to sell these in diy kits in the near future. I am still figuring out the logistics. Here is the compatibility list:
Mobo: mini-itx
CPU cooler + case fan total height: 47mm
Case fan: 120mm or 92mm mounting holes, will fit up to 140mm provided mounting holes line up.
GPU: none
PSU: pico with mounting for 5.5mm/2.5mm. Should also fit 5mm/2.5mm.
I/o: only single 14mm vandal switch in the rear.
Likely cost for a kit: $70-80 for popular colors. Includes all the hardware to get you started.
Color combos: one offs, well just message me! The side panels can come in most colors that available in acrylic, however, the minimum run has to be 3 unless you are willing to pay extra. 3d printed parts can come in: white, black, blue (pictured), pink, red, purple, yellow, green, orange.
That's it! I am still working out the logistics for revision 2 but it should be available in a few weeks. Let me know if you're interested and I'll add you to the mailing list.
Full gallery can be viewed here: Stratos 3 in Glossy White
Reactions: Jspr
