Monkey34
- Apr 11, 2003
Yesterday I plugged it in and transferred about 2gigs of files to the external (it has always worked fine) from this Xp pro rig.After it was done, I tried to "safely remove" and it said it was busy to try later, so I gave it a min and tried again. Still busy. I gave it another couple of mins, and it still said try later.....so being impatient I yanked the cord. ((shouldn't take THAT long)).
Well, I got a message in the taskbar about System Volume Information\EfaData\SYMEFA.DB-journal for the G: (external) corrupting. Evidently this is a Symantic file, but the drive is just storage....so why would it say G? Anyway, this directory and file dont exist on the external, but do on the C; drive.
On to the wierdness. The external is no longer seen on this rig as a "verbatim", shows no files, and shows as "RAW".
ON THIS RIG ONLY.
I plugged it into other rigs (XP pro, Vista, 7) and they all see it fine normally. All the files are there.
Scratching my head at this.
ON THIS RIG ONLY.
