I have an ASUS P8P67 deluxe MB (version 3) and a Vertex 2 120GB drive, my problem is randomly it hangs for a period, it normally only lasts a minute or so, and running tasks continue, without issue, but starting new tasks fail, the cause seems to be that the executables can not be found, literally they do not exist. My best guess is that I loss connectivity or at least the ability to write to the SSD (Drive C:\ ) during this period and when access returns all is fine and anything I did responds instantly, but worst case is it does not return and I'm forced to reboot the system (hard by holding power this has only happened twice). I'm using the SATA6 port on the MB, but it also happened with the Marvell controller, and I'm already using the 4 Intel SATA3 ports on the MB.
Has anyone seen or heard of anything similar happening, is there any known issues between the SATA6 adapter and SSD drives?
Thanks,
ERIC
Thanks,
ERIC
