Rune75
- Aug 16, 2004
I want to go small(er). Going from ATX mobo, 10x5.25 bay full tower, and 12 HHDs to ITX with close to the same storage capability. I do not want a dedicated graphics card. Been thinking of buying a bitfenix prodigy case and mounting more HDD above the mobo from the top of the case. I would like to end up with 9-10HDDs in there. Is this a pipe dream?
1. What will you be doing with this PC? a) HTPC b) NAS
2. What's your budget? 1K-1200$ with tax can go a bit higher for shipping
3. Where do you live? Bremerton, WA. I have a BB 15 minutes away and a Fry's 45min away
4. What exact parts do you need for that budget? ITX Z77 or better, 8-16GB ram, i5-3570K or i7-3770 or close, 1xSSD 240GB+, 550-650watt modular psu, PCIE SATA 6Gb card 4-8ports, Bitfenix Prodigy case (or other with more HDD slots). NO OPTICAL DRIVE.
5. If reusing any parts, what parts will you be reusing? I've got 6x3TB WD or more green drives that will be in the case.
6. What specific features do you need in a motherboard? Required: The more SATA 6Gb the better, onboard graphics, USB3 front and rear. Wanted: Gigabit ethernet.
7. What resolution output do you need? Onboard graphics capable of 1080p video playback to HDMI in my receiver or TV. No multi-monitor.
8. Does this system need to fit into a particular space? Kinda small but not tiny. Prefer Bitfenix Prodigy or smaller.
9. How comfortable are you with custom case design/modification and electrical wiring? I'm fine with tinkering and modifying. Been building PCs since 1989. I have Screwdrivers/Leatherman, Drill, Dremel, Metal snips, Soldering Iron. Access to plasma, water, & laser cutters.
10. How important is the noise/silence of this sytem? The quieter the better. Not water cooled, but I'd like to keep it around 20 to 30ish dB if possible.
11. How mobile does this system need to be? Pull it out to dust every few months
12. Do you already have a legit and reusable/transferable OS key/license? Friends at MS. Full retail versions of Win7 Pro 32/64. Will have Win 8 Pro 32/64 too. Can use FreeNAS or other so long as
13. When do you plan on building/buying the PC? Within the month
Questions, advice, thoughts, or laughter?
