Axman
- Jul 13, 2005
Neat. Maybe someone will make a drop in backplate with a machined heat spreader … if it fits in the carry case, I’d buy one for sure.
Hi! You must be new to LTT.The external heatsink is stupid.
Lol no, I've seen his videos since the beginning. It seems like they go through waves of decent content and crap content. Also his new hair cut is stupid. When he grew the beard he somewhat seemed like a man.... the hair kills it now though lol.Hi! You must be new to LTT.
I just find it off putting that a guy nearly my age acts so immature. I guess it works with the younger audience though, he seems a lot more normal on his podcast though.
The heat sink mod is not impossible to do practically though. I have a 3d printer sized cnc router that is "supposed" to be able to cut aluminum.
If I were going to do it. I would get a spare back case and cut it out to fit a 1/4" thick aluminum plate with fins machined into it Have it run left to right over 3/4 of the back area of the device. Mill out the center for a low profile fan and but a plate on top of the heatsink to cap it off and force air flow and have vents on both ends to exhaust hot air.
Not to scale, because I just grabbed a random fan off grab cad, but it wouldn't matter anyway. You would need to mod it to raise tdp to get any use out of it.
As a long time Rush fan, I always naturally liked LinusHe has a big enough platform that the message can be heard loud and clear (even if a little high pitched).![]()
Lucky!Finally got my email - July 19, 2021 to Aug 1, 2022. Might have it by the end of the week.
