Why hasnt anyone mentioned Wasabi Mango? especially with the 120hz 40" 4k panel that should be shipping now
Didn't know about that, pretty neat. OP did ask for 27" monitor recommendations though so most of us have been steering towards that size and discussing 32" as a maximum. 43" is full blown TV size.
Hey everyone!
Since 4k is where things are going in long terms, I am thinking about upgrading to 4k... so I started digging again (just months ago I've had 240hz, gsync, 144hz, multiple ips montiors and now have simple hp 27ea as a nice stop gap) and the market is still in a weird/bad place.
TV's are 5 years ahead but only if we talk about 42"+ and that is too big almost for any desk and defeats purpose of high ppi monitor. Unless there are smaller good tv's which I don't know about. It's crazy anyway that 4k 42" hdr is cheaper than 27" monitor.
I think that when talking about 4k we should consider 27-32 monitors and mainly 60hz for now due to there not being much else and pc specs not being there yet and ppi doing the best work at those sizes.
There is also a question of HDR and FALD. There are already HDR10 monitors on the market that properly "accept" hdr 10 signal like LG 27UK line or dell U2718Q. There are also monitors with fald zones from Dell or Asus but they suck, are very expensive and create halos around brighter objects. Nowhere close to oled or hdr on ips tv's.
So there might not even be a point of getting fald or even a 4k monitor that accepts hdr10 signal if it cannot properly display it.
So... that said, any recommendations for 27" 4k monitor? Probably ips without fald zones or hdr10 since it's useless anyway. I want to use it on ps4 and pc.
Anyone experienced with those? I'v seen some reviews and 600:1 contrast does not sound good... if these were at least 1200/1300:1 like 1080p ips monitors are, it would not be so bad. But being that I am used to 27" 1080p, 6bit monitor... 4k, 10bit should at least be some upgrade right?!
IMO, 4K looks really bad on a 27". The fonts are way too tiny. I've had that Dell U2715Q, did not like it.
4K looks really good on a 32" display. It just works. the PPI is a useful 137 on a 32" versus an impossible 163 on a 27".
I like my PPI to range from 115 on the lower end to 140 and 137 is perfect.
I realize you can use the scale function and get it to 140% or something but then why get a 4K 27" when you can just get a QHD (2.5K) 27" which looks just as good?
I know what scaling is. If I am going to use scaling, to buy an expensive 4K or 5K machine and then scale it down to something else, I might as well just buy the specs that I will be scaling down to.
If I won't use the native resolution, I won't buy it.
Fair enough, you like your fonts rendered pixely. Others work with text all day and want crisp text, there 27" 4k, 32" 4/5k, etc. shines. The standard 96PPI just doesn't cut it for text rendering, and that we were stuck with it for so long is a shame really. Now the options are here, you don't like them, don't buy them.I know what scaling is. If I am going to use scaling, to buy an expensive 4K or 5K machine and then scale it down to something else, I might as well just buy the specs that I will be scaling down to.
Apple was smart about it but their closed garden approach helped them a lot here. They could afford to push for 2x scaling in their products since they control what resolutions those ship with. Microsoft mostly didn't have this luxury. The good thing about 2x scaling is you can just show same content in 4 pixels instead of 1 where proper resolution content is not available, so at the worst it will look the same as the user remembered it, never worse. Personally I find 4k adequate for 32" and text is sharp enough. 5k would be nice to have the 2x scaling for old applications but those are few and for most you have alternatives that are PPI aware so it's not really a problem anymore. However we would also need monitor or GPU integer scaling (or both) for 5k to be really useful, so 4k will probably be where they stop for now.I can definitely see why Apple pushed the DisplayPort standard a bit to get 5k in 27"- it works out extremely well with various forms of scaling, whereas I found that scaling on my 32" 4k was less than optimal. Probably need 6k for 32" to get reasonably sharp scaling results.
