Krispy Kritter
- Feb 13, 2003
OK. So after all the hype, I'm looking at installing an SSD in my main rig. I'm currently using a Gigabyte GA-P55A-UD4P. The board has two SATA III ports, however, it uses a Marvel chipset.
With that said, I was looking at the Kingston HyperX 120GB (based on the Hard review). I'm just curious if I will even see those speeds, or if a cheaper SSD would make more sense in this setup. And if so, which SSD models are recommended?
