I recently received a call from a friend to fix his spyware infested computer. It looks like the issue has exploded since they first started receiving pop-ups and now the computer never reaches an operational status on normal boot. Spyware loads and loads and the system hung for a good 30 minutes straight. I couldnt even get Task Manager to kill programs. Where they picked up this mess or what its called I have no idea yet as I havent been able to do any work in Windows.
I took the machine offline so it wouldnt be broadcasting PII and tried booting into Safe Mode. After 30 minutes trying to load Safe Mode I gave up. I would get the start of the desktop with the Safe Mode indicators at the top and bottom of the screen but no task bar.
I know that I can run an install over the top of the current installation and probably get the system to where I can use it and start cleaning out Spyware and backing up important files.
If anyone has any tips or tricks to share Im all ears.
(Windows XP Home SP3)
